HDD DVR and HDCP problem - AVS Forum | Home Theater Discussions And Reviews
Old 11-26-2013, 07:43 AM - Thread Starter
LinR1947's Avatar
When I connect my new TV to my cable box via HDMI for hi-def, my HDD DVR keeps getting an error about HDCP incompatible port. Any recommendations for hookup?
LinR1947 is offline
Old 11-26-2013, 09:31 AM
Kelson's Avatar
Quoted: 1950 Post(s)
Liked: 1146
Is your "HDD DVR" supplied by the cable company? If it is, you call them to resolve their issue. If not, what is it and how are you connected now going from the cable outlet on the wall. The more details you provide the more likely someone will be able to contribute meaningfully.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Old 11-26-2013, 10:46 AM
jjeff's Avatar
Quoted: 687 Post(s)
Liked: 245
Model number of TV would also be helpful, I believe some computer monitors with HDMI input may not support HDCP.
jjeff is online now
Old 11-27-2013, 09:12 AM - Thread Starter
LinR1947's Avatar
It's a Magnavox HDD DVR......seems like there is no "handshake" between the DVR and any of the TV's hi-def ports. HDMI doesn't work, co-ax doesn't work, and Red/Green/Blue doesn't work. But connection of RCA cables (R/W/Y) out of DVR to tv seems to work. I don't really care about recording in hi def.....all I want to do is record my network shows so I can fast forward without suffering through those awful commercials.
LinR1947 is offline
Old 11-27-2013, 09:23 AM
JSUL's Avatar
Liked: 41
It is likely you have a defective box from your cable company....or the cable company has kicked out those inputs, which is bizarre, but known to happen.
You need to get your cable company involved asap.
JSUL is offline
Old 11-27-2013, 11:14 AM
Kelson's Avatar
Liked: 1146
Originally Posted by LinR1947 View Post
It's a Magnavox HDD DVR.......
Are you talking about a Magnavox DVD Recorder?
- kelson h
Kelson is offline
Old 11-27-2013, 11:56 AM
jjeff's Avatar
Quoted: 687 Post(s)
Liked: 245
I would say it sounds like that.
To the OP, what outputs are you using from your STB to DVDR? and I take it you want to watch both your STB and DVDR via HDMI?
Some STBs will disable other outputs when using HDMI. You should be able to watch both your DVDR and STB via HDMI to your TV, not sure why you'd get the HDCP warning on your TV though...
jjeff is online now
Old 11-27-2013, 02:53 PM
Kelson's Avatar
Liked: 1146
If it is then it belongs in the DVD Recorder forum where his problem has probably already been answered half a dozen times already.
- kelson h
Kelson is offline
Old 11-27-2013, 03:05 PM
Super Moderator
DrDon's Avatar
Quoted: 868 Post(s)
Liked: 1726
LinR1947
As requested, please provide the MAKE AND MODEL NUMBER of all of the devices we're discussing.
I'm afraid you've wasted a day getting information we could have supplied if given this information.
If that's not something you care to do, then I'm afraid I'm going to have to delete this thread.
We're only trying to help.
Make and model of the TV
make and movel of the DVR
Make and model of any other piece of equipment involved here.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Old 11-28-2013, 07:18 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Wouldn't this be better suited for this sub-forum?;
http://www.avsforum.com/f/168/hdmi-q-a-the-one-connector-world
At least you can see all the others with similar problems thanks to Hollywood's greed (among others).
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
