Very Weak Signal with RNG110 - Drop Amp Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-06-2013, 12:56 PM - Thread Starter
legstrong337's Avatar
Hi guys, I hope this is the right forum for this question.
I've been having really bad signal issues with my Comcast Cable. I have a RNG110 STB. As far as cabling goes, it's all RG6 and there are no splitters running to the TV. I just installed a Motorola BDA-K4RA drop amp (4-port w/ active return), and there was a clear improvement in the signal, however, the signal is still too weak. There is major pixelation and freezing on some channels on my HDTV. The other ports on the drop amp have terminators on them at the moment, but I will be hooking those up to give three more bedrooms cable TV in the house.
These were the readings on the diagnostic screen:
Before Drop Amp
Upstream: 38
OOB: -28.1
IB1: -13
After Drop Amp
Upstream: 60
OOB: -13.0
IB1: -3.8
The signal is still a little too weak. So here is my question: Should I take the cable when it runs into the house, install a 2 way splitter, and then use TWO drop amps. One would be a single port that would go directly to the TV, and the other would cover the rest of the house. The reason I'm thinking this would work is because the TV is at the farthest point in the house, with the cable run being at least 100 feet. I'm hoping that the single port drop amp would amplify the signal more than the 4-port drop amp, and thus give the TV the stronger signal.
Current Setup
Cable->Drop Amp (4-port)->TV, terminator, terminator, terminator.
Proposed Setup
Cable->2-Way Splitter->Drop Amp (4-port)->Bedroom TV, Bedroom TV, Bedroom TV
                       Drop Amp (1-port)->TV
Does this make sense, or do you think it would even work? Or does adding a single port drop amp do the exact same thing as a 4-port?
legstrong337 is offline
post #2 of 4 Old 12-07-2013, 07:00 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Wrong forum, try here;
http://www.avsforum.com/f/25/hdtv-technical
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #3 of 4 Old 12-08-2013, 07:40 AM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
You don't want a splitter before the amp. That weakens the signal. The amp will serve as an amplified splitter. And you don't need 2 amps. Use one amp and the 4 ports will serve all TVs. If the signal is too weak as you say, then the cable company needs to boost the power of the signal as it enters your house. That is where the problem may be. Then your single 4-port amp should work fine.
tylerSC is offline
post #4 of 4 Old 12-08-2013, 12:39 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Before Drop Amp
Upstream: 38
OOB: -28.1
IB1: -13
After Drop Amp
Upstream: 60
OOB: -13.0
IB1: -3.8
Current Setup
Proposed Setup
Actually the only thing that would make sense in your situation would be to have the cable guy out to fix it. Odds are if your signal level is that piss-poor you've also got bad signal to noise and no amplifier will correct that.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply HDTV Recorders
