Is this my TiVo's problem or my Cable Provider? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-04-2014, 01:07 PM - Thread Starter
tanglin's Avatar
Can anyone suggest the likely place to point a finger, or something to do to determine where to do so...
My TiVo (Premier XL4), is connected to my cable provider (Cox, Orange County) via a tuning adapter. On live TV, on only 2 channels I can determine (1054/1057) the video cracks up and is unwatchable.
I checked the TiVo diagnostics and 1054 for example was on tuner 3. The signal varies from 75-78% and 0% (nothing in between), and the 0% stays there for a few seconds and it returns back up. On the other tuners their channels seem to lock OK to 75% or thereabouts.
Cox's initial supposition is that it's a TiVo problem, but I am not sure.
Keith
tanglin is offline
post #2 of 9 Old 01-06-2014, 05:46 PM
bidger's Avatar
Keith, when you call for assistance are you calling 1-877-820-8202 or your local office? I believe the number I mention is their national CableCard support number so they would be more helpful than the local office for issues like this. Also, are these channels on demand or PPV? Finally, have you called TiVo about the issue?
bidger is offline
post #3 of 9 Old 01-07-2014, 04:53 AM - Thread Starter
tanglin's Avatar
I was calling the local office (Cox OC).
The channels are part of the basic digital package, not PPV/Demand. They seem to have deteriorated since Cox gave the modem a hit.
I have not tried calling TiVo yet, wasn't sure if it was their problem or not.
Keith
tanglin is offline
post #4 of 9 Old 01-07-2014, 06:30 AM
mdavej's Avatar
Quoted: 2273 Post(s)
Liked: 992
Those signals aren't that great. I think the problem lies with your service, not the TiVo. Do you have any other cable boxes in the house that also have this issue?
mdavej is online now
post #5 of 9 Old 01-07-2014, 06:47 AM
Thread Ender
WS65711's Avatar
Quoted: 510 Post(s)
Liked: 341
If the problem is "yours" it's more likely a bad/poor coax than the TiVo itself. If you have other tuners that work fine, try changing the coax or moving the TiVo temporarily to a different TV location. In my personal situation, I always find that the Tuning Adapter reduces the signal to the TiVo by a dB or two. If your signal level is borderline to start with, that can be a killer...
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #6 of 9 Old 01-07-2014, 07:06 AM
mdavej's Avatar
Liked: 992
Good point about the TA. I have to split before my Moto TA. If I go thru it, the signal takes a huge hit. I think Cisco TA's aren't quite as bad.
post #7 of 9 Old 01-07-2014, 08:09 AM - Thread Starter
tanglin's Avatar
No, just the TA and TiVo. I have other TVs but they don't use digital (except QAM) and those channels are not a part of this.
Keith
tanglin is offline
post #8 of 9 Old 01-07-2014, 08:10 AM - Thread Starter
tanglin's Avatar
I can't recall exactly but I am thinking I am getting 27-30 dB. I'll check.
Keith
tanglin is offline
post #9 of 9 Old 01-07-2014, 08:41 AM
mdavej's Avatar
Liked: 992
That's fairly low. I get close to 37dB. Just a 3dB drop is a 50% loss.
Reply HDTV Recorders
