Have two DVRs and the remotes for one also contol the other. How do I change one? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-10-2014, 07:08 PM - Thread Starter
snickernator's Avatar
Two DVRs:
   1. Motorola DCT 6416 III
   2. Motorola DCX 3400 M
The 3400 M was a replacement for another 6416, due to failure of that box.
The problem I have is that the remote for the 6416 is controlling the on/off and channel changer on the 3400, and vice versa. We did not have this issue when we had two 6416s. I'm assuming  there is a code somewhere in the set top box that determines what version of the various remote code sets it recognizes.
Is there a way to change the setting on the 3400 so that it doesn't respond to my 6416 remote?
The provider is Suddenlink, though the 6416 remote has the Cox Communications logo on it.  (Suddenlink bought the local Cox affiliate several years ago.)
snickernator is offline
post #2 of 12 Old 01-10-2014, 09:40 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
No
mdavej is offline
post #3 of 12 Old 01-11-2014, 02:38 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Two DVRs:
(Many) years ago, I had the same problem on two VCRs. I had a bunch of old photography filters laying around. I put a vertically polarized filter in front of one VCR sensor, and a horizontally polarized filter in front of the other. Then, simply orientating the remote in either the vertical or horizontal plane determined which VCR got the signal. YMMV.
videobruce likes this.
domino92024 is offline
post #4 of 12 Old 01-11-2014, 06:12 PM
Primestar31's Avatar
Quoted: 73 Post(s)
Liked: 45
You could also open them up, and wire a spst switch in series with the IR sensor.
Flip it to OFF, and that dvr will no longer respond to the IR signal. You can then program the OTHER one during that interval while the switch is off.
Primestar31 is offline
post #5 of 12 Old 01-11-2014, 08:03 PM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
When I was in a similar situation, a very low-tech solution worked for me: a piece of corrugated cardboard placed in front of the remote eye on the DVR that I did not want to respond to the signal.  Having to get up and go to the DVRs to move the cardboard from one DVR to the other wasn't nearly the effort of having to get up and go to the TV itself to use its knobs or dials for every function as we did in my youth, so I didn't mind it much.
dattier is offline
post #6 of 12 Old 01-11-2014, 11:26 PM
Quoted: 126 Post(s)
Liked: 216
Just turning off the power switch would give the same results. I tried to give a solution that would not require trip(s) out of his chair. Some of us are disabled.
post #7 of 12 Old 01-12-2014, 12:43 AM
Quoted: 73 Post(s)
Liked: 45
A filter could be a good way to go, I wasn't aware of them working like this, so thank you, and please realise my post in no way was any comment on your filter post.
You really don't want to completely power cycle dvr's frequently for a purpose such as this, and many don't even have on/off switches. Dvr's are meant to be up and running 24/7. A switch that simply disables the IR is an easy and cheap solution that few thinks of. For a person that is disabled, you can purchase and install a remote on/off switch. It's a choice to make the OP aware of, and then he can decide and try what he so chooses.
post #8 of 12 Old 01-12-2014, 01:35 AM
Aleron Ives's Avatar
Quoted: 1580 Post(s)
Liked: 1289
The 24/7 uptime is necessary for DVRs that constantly update their schedules to do name-based recording, but it is not a necessity of all DVRs. Ones that do time-based recording can turn themselves on when it's time to record and then power down again, just as a VCR would.
Aleron Ives is offline
post #9 of 12 Old 01-12-2014, 01:23 PM
Quoted: 126 Post(s)
Liked: 216
DVRs that have an ON/OFF button aren't even close to being off when switched as so. They are merely in "stand-by." An "off" DVR receives its schedule updates just fine in this mode.
post #10 of 12 Old 01-13-2014, 07:21 AM
mdavej's Avatar
Liked: 940
BTW, you can always throw money at the problem and get an addressable IR system. But I like the polarized filters myself.
mdavej is offline
post #11 of 12 Old 01-13-2014, 09:06 AM
Suddenlink Help's Avatar
Hi snickernator – My name is Shannon and I am with Suddenlink. I would be happy to look into this further for you and assist in a resolution. Please contact me via email at shannon-AT-suddenlink-DOT-com. Thank you!
Suddenlink Help is offline
post #12 of 12 Old 01-13-2014, 01:24 PM
mdavej's Avatar
Liked: 940
Since Suddenlink is offering to help, just ask them for a different brand box to replace one of your Moto's. Problem solved.
mdavej is offline
Reply HDTV Recorders
