Component video output not working - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2014, 08:03 AM - Thread Starter
Jefferson62's Avatar
Hi,
My component video output is not working the same
I have my TV connected using the component video output thru an A/V switch box to a 30' cable connected to the TV. This setup worked fine for the past few years, but last night I got no signal on the TV.
I removed the A/V switch box and connected the cable box directly to the 30' cable and that didn't work.
I connected the cable box out using a 6' cable to another TV and that worked.
Is it possible the the output of the cable box has changed and is not strong enough to use the 30' cable anymore?
Are their any settings I could look at in the diagnostic menu that may provide any help?
Jefferson62 is offline
Old 01-16-2014, 09:18 AM
Kelson's Avatar
Quoted: 1953 Post(s)
Liked: 1147
Re-seat all the connections on both ends of the cable first. Sometimes slow oxidation can take its toll. Then get a volt-ohm meter and check the electrical integrity of the cables. Make sure nothing has broken or otherwise introduced a large resistance across the cables.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Old 01-16-2014, 09:19 AM
Super Moderator
teachsac's Avatar
Quoted: 659 Post(s)
Liked: 989
Please post in the thread for the model of your box.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 01-16-2014, 12:16 PM - Thread Starter
Sorry, I thought I was posting to a different thread.
I have a Pace TDC787 DVR.
Also, I hooked the same cables to my DVD player and it worked fine.
So it seems to be only the DVR that has the problem. I will check the resistance of the cables anyway.
