HDTV RECORDERS FOR PLAYBACK ON TV OR COMPUTER - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-20-2014, 08:16 AM - Thread Starter
VIDEO J's Avatar
I purchased a Brite View 980H (unfortunately).  It stopped working. I want to replace it with something reliable.  But everything I have found so far only plays back on a computer.  Is there any product that will record TV shows and play them back on a tv set
VIDEO J is offline
post #2 of 14 Old 02-20-2014, 08:50 AM
Thread Ender
WS65711's Avatar
Quoted: 491 Post(s)
Liked: 326
TiVo.
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #3 of 14 Old 02-20-2014, 09:42 AM
videobruce's Avatar
Quoted: 603 Post(s)
Liked: 246
Have you seen this?;
http://www.avsforum.com/t/1460149/updated-list-of-consumer-available-dvrs-available-in-the-us/0_60
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #4 of 14 Old 02-20-2014, 10:18 AM
Kelson's Avatar
Quoted: 1953 Post(s)
Liked: 1148
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #5 of 14 Old 02-20-2014, 10:32 AM
videobruce's Avatar
Quoted: 603 Post(s)
Liked: 246
One sided.
post #6 of 14 Old 02-20-2014, 11:22 AM - Thread Starter
VIDEO J's Avatar
Thanks videobruce.  I looked at the list.  I can eliminate the first one, Brite-View/Zinwell.  From personal experience I can confirm that it is a piece of junk.  I'll look into the others to see if one of them fits my needs.
VIDEO J is offline
post #7 of 14 Old 02-20-2014, 01:03 PM
mdavej's Avatar
Quoted: 2131 Post(s)
Liked: 942
You do realize it's quite easy to connect your computer to your TV or use an extender or XBMC client and use a normal IR remote to control it like you do today. It's much cheaper than Tivo and far better than other standalone recorders that have no guide, no ability to record copy protected channels, no multi-room capability, no remote streaming and have only a few tuners.
mdavej is offline
post #8 of 14 Old 02-20-2014, 02:26 PM
jjeff's Avatar
Quoted: 697 Post(s)
Liked: 246
What outputs do you need? When you say "TV" do you mean channel 3 or 4 RF or does your TV have line inputs(composite, HDMI, etc.)?
If your looking for something that just works then the most expensive option(a Tivo) is probably your best bet, a less expensive option but less flexable and potentially more "issues" would be a CM+ DVR(but it only has HDMI output), from your description I would not suggest something like a iView or Homeworx DVR, they are very inexpensive and have many different outputs including RF but more of a hobby than a set and forget it device. You also didn't mention if you were OTA or cable, something like the CM+ only works from an antenna.
laridae likes this.
jjeff is offline
post #9 of 14 Old 02-21-2014, 08:05 PM - Thread Starter
VIDEO J's Avatar
My setup is very simple.  I receive tv signals through a digital antenna, which is cabled to my digital tv.  So, I am looking for a recorder to put inline to record shows for playback later on the tv.
VIDEO J is offline
post #10 of 14 Old 02-22-2014, 05:30 AM
videobruce's Avatar
Quoted: 603 Post(s)
Liked: 246
Then have you looked at the link in post 3??
post #11 of 14 Old 02-22-2014, 07:04 AM - Thread Starter
VIDEO J's Avatar
I have looked at the links.  Being limited in my knowledge of electronics, I find a lot of the information goes right over my head.  In the case of the Magnavox and Phillips units, I did not understand most of the negative comments, but got the feeling that neither is what I should buy.  On the other hand, I got just enough out of the comments on the ChannelMaster to conclude that it would work, but needs an external hard drive for doing any significant amount of recording.  The days of analog were simple.  By a VCR and hook it up inline.  I get the feeling that digital isn't that simple.
VIDEO J is offline
post #12 of 14 Old 02-22-2014, 07:30 AM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
You are in good company; many others are wondering about that as well:
http://www.avsforum.com/t/1504128/why-are-there-no-name-brand-ota-dvrs
Cable-free since Nov 2013
laridae is offline
post #13 of 14 Old 02-22-2014, 08:06 AM
Thread Ender
WS65711's Avatar
Quoted: 491 Post(s)
Liked: 326
....  The days of analog were simple.  By a VCR and hook it up inline.  I get the feeling that digital isn't that simple.
Blu-rays & DVD's
WS65711 is offline
post #14 of 14 Old 02-22-2014, 08:18 AM
videobruce's Avatar
Quoted: 603 Post(s)
Liked: 246
With a VCR you needed tape, with a DVR you need a HDD.
Reply HDTV Recorders
