HDTV Recorders - AVS Forum | Home Theater Discussions And Reviews
Old 02-24-2014, 04:54 AM - Thread Starter
Hallmerk's Avatar
Quoted: 17 Post(s)
I'm new to this forum but and I do not understand why the latest firmware on the manufacturers site is version 9 instead of 13?  Can anyone explain that in detail!
Also, I need a box that has a strong tuner because I have lots of pine trees and pixelation is a problem even though I am 12 miles from the transmitters.  I am using an outside antenna with pre-amp.  I am only using the box for over the air reception.  Which version of the firmware would give me the strongest OTA tuner!  Thanks
Hallmerk is offline
Old 02-24-2014, 06:59 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Just a suggestion, but you may want to add what piece of equipment you are asking about to your question.
joed32 is offline
Old 02-24-2014, 07:26 AM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
Sounds like the Homeworx 150PVR. If so, you'll find a lot of info on their thread, including various rants and speculation about their counter-intuitive firmware numbering "system", if you can call it that!
Cable-free since Nov 2013
laridae is offline
