Channel Master PVR + (CM 7500) and Slingbox 500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-25-2014, 09:45 AM - Thread Starter
David Graham's Avatar
Has anyone been able to connect the new Channel Master PVR + (CM 7500) to a Slinbox? I tried all morning and could not get it to work. The Slingbox says to connect composite cables to the Channel Master and the Channel Master does not have any.
Suggestions? Help?
David
David Graham is offline
post #2 of 2 Old 02-25-2014, 02:19 PM
Aleron Ives's Avatar
Quoted: 1680 Post(s)
Liked: 1438
Adapters to convert HDMI to analgue signals can be expensive, so you'd be better off getting a cheap DVR that has its own composite output, such as an iView or Homeworx. If the Slingbox only supports composite inputs, though, you're not getting HD, so an HD DVR is wasted. You might as well get a Magnavox DVD/HDD recorder if you're only dealing with SD.
Aleron Ives is offline
Reply HDTV Recorders
