3.5 HDD vs. 2.5 HDD - AVS Forum | Home Theater Discussions And Reviews
Old 02-25-2014, 06:10 PM - Thread Starter
Pilule's Avatar
Did anybody have any issue with using a 2.5 HDD with it's power drawn from the HDTV Recorder? Like the power supply failing?
I'm debating if I should set it up with a 2.5 HDD that gets it's power from the unit versus a 3.5 HDD that has it's own power supply. My number one choice is a 2.5 as long as it doesn't overload the power supply of the unit.
Pilule is offline
Old 02-26-2014, 04:32 AM
videobruce's Avatar
Quoted: 602 Post(s)
Liked: 246
It depends on the draw of the drive and the capabilities of the supply. heat is the issue. As long as the draw isn't excessive and the supply is cooled, there shouldn't be a problem.
3 1/2' drives have to be powered separately.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
Old 02-26-2014, 08:07 AM
Super Moderator
teachsac's Avatar
Quoted: 659 Post(s)
Liked: 1000
Duplicate asked in iView thread.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
