Caution when powering down the DVR+ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-22-2014, 02:25 PM - Thread Starter
Roger Pratt's Avatar
  I powered down my DVR+ to move it. When I reconnected it said the HDD had been disconnected, reconnect and push continue. I did, now i am stuck at the grinding gears. Tried a few things to get it to boot, no luck.
  Contacted CM, have to return it. Was told there is a bug in the software. You have to delete everything in the you have scheduled to record if you want to power down the unit. They said this will be corrected in the next update.
  Would have been nice to know about this little problem! I ordered my DVR+ from CM seems like an email could have been sent to the purchasers.
  All in all I have been happy with the device. The guide information could stand improvement, but that goes for all the guide data from all sources. It seems like sticking to the schedule is a thing of the past.
Roger Pratt is offline
post #2 of 6 Old 04-25-2014, 07:40 AM
dattier's Avatar
Quoted: 147 Post(s)
Liked: 62
Does the same thing happen if you experience a power outage?
dattier is online now
post #3 of 6 Old 04-25-2014, 10:27 AM - Thread Starter
I am going to contact CM when I get my DVR+ back and get more details on this problem. I will post anything I find out.
post #4 of 6 Old 05-01-2014, 08:17 AM
bsprague's Avatar
Quoted: 595 Post(s)
Liked: 217
I turn mine off about once a week. It is in a motorhome and I change locations about that often.
bsprague is offline
post #5 of 6 Old 07-15-2014, 05:41 AM
dervari's Avatar
Quoted: 14 Post(s)
If it's running a flavor of Linux, I'm guessing just powering it off can cause filesystem or database (MySQL?) corruption in certain instances.
dervari is offline
post #6 of 6 Old 07-15-2014, 08:12 AM
Kelson's Avatar
Quoted: 2007 Post(s)
Liked: 1201
That would be really poor design. Power outages happen all the time and the DVR needs to be designed to handle them. I know in the case of TiVo (also Linux) if the power goes down then comes up while in the middle of a record, when the power comes up the system reboots and goes back to recording the show that it was recording. The pre and post-outage segments are stored in separate files.
I don't know that the DVR+ will resume a record after a power failure, but it certainly should not crash in a way that corrupts the file system of the existing recordings.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Reply HDTV Recorders
