why do i get much better OTA reception on 3500STBII vs HW-150PVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-01-2014, 02:03 PM - Thread Starter
sotwell's Avatar
Quoted: 102 Post(s)
I just bought both units. Hooked both up to the same TV, same OTA antenna. the 3500 gets me 100% reception and the 150PVR is around 30%-40% with constant drop outs. Both units look similar. Why is one so different?
sotwell is offline
post #2 of 3 Old 05-01-2014, 02:14 PM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Are they hooked to the same RF connector or is one daisy chained to the next? If you disconnect one and then hook up the other and still get much different readings I'd suspect an issue with the Homeworx unit...have you tried any different firmware versions for the Homeworx?
jjeff is online now
post #3 of 3 Old 05-01-2014, 02:33 PM - Thread Starter
sotwell's Avatar
Quoted: 102 Post(s)
I'm just disconnecting and reconnecting. Big difference in performance. I have not tried different firmware
sotwell is offline
Reply HDTV Recorders
