comcast motorola dcx3400 power toggle? - AVS Forum | Home Theater Discussions And Reviews
Old 06-09-2014, 09:33 PM - Thread Starter
mumulee's Avatar
i own a logitech harmony ultimate and i use it with the comcast motorola dcx3400. anyone have issues with the comcast motorola dcx3400 not turning off after recording a programmed dvr show? when pressing the logitech harmony remote to turn on the dvr, it turns it off because the dcx3400 failed to power off after recording a programmed dvr show.
Samsung UN75H7150 75" LEDTV
Samsung BD-P1500 Blu-ray player
Onkyo TX-NR828 receiver
Paradigm Monitor 7 v5 floor speakers & CC-190 center
Paradigm Atom v6
SVS PB1-ISD subwoofer/Logitech Harmony Ultimate
mumulee is offline
Old 06-10-2014, 10:28 PM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
You can use Help on the Harmony to get back in sync, or just leave the DVR on all the time. There's virtually no difference in power use whether is on or in standby. To do that, change the power options of the device in Harmony to no power or change activities to not send any power commands to the DVR. Moto boxes have no discrete power commands like other DVRs from satellite or U-verse do. So there isn't much else you can do.
mdavej is online now
Old 06-11-2014, 06:41 AM - Thread Starter
mumulee's Avatar
thanks mdavej. i will do that tonight.
Paradigm Atom v6
mumulee is offline
