Taikwong Digital HDD 1080P HDTV HDMI - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By qz3fwd
post #1 of 15 Old 08-10-2014, 09:10 AM - Thread Starter
jobedo's Avatar
Saw this on Amazon http://www.amazon.com/dp/B00KVCGV5K?psc=1
Now if these were 99.99$ i would try one
Joe
jobedo is offline
post #2 of 15 Old 08-10-2014, 11:45 AM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Whats the easiest way to tell what Amazon that post links to?
It says Amazon/dp and I'd assume Taiwan from the product but dp and Taiwan don't exactly make sense
jjeff is offline
post #3 of 15 Old 08-10-2014, 04:19 PM
larryccf's Avatar
Quoted: 108 Post(s)
be nice if someone offered a hdmi video filter.......
'A good police force is one which catches more crooks than it employs.' quote, Sir Robert Mark, Commissioner of the Metropolitan Police UK
larryccf is offline
post #4 of 15 Old 11-11-2014, 01:45 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
Why is this posted in a DVD recorder forum?? It's a HD DVR.
Some additional details;
http://producthit.com/taikwong-digit...cer-match-rec/
http://www.tvbrands.hopsforheros.com...-recorder.html
I'm still looking for the "BluRay player" it supposedly has.
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #5 of 15 Old 11-11-2014, 10:37 AM
larryccf's Avatar
Quoted: 108 Post(s)
Good catch on that - i'd speed read it and also thought it had it's own blu-ray player. Suspect whoever wrote that descript, that english isn't their native tongue.
still i'd love to see someone's report on this unit - and if they're able to play back hdmi protected video on their computer after "re-arranging" the files.
larryccf is offline
post #6 of 15 Old 11-11-2014, 02:04 PM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
I saw the same thing in 4 or 5 other sites regarding this product.
Judging by the size and the fact it's a no name Chinese outfit, $100 is all it's worth. It looks the same size as that iView.
post #7 of 15 Old 11-12-2014, 03:37 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
Here are some more details;
Name:	Taikwong HD Recorder 02.png
ID:	362906   Click image for larger version
Name:	Taikwong HD Recorder 03.png
ID:	362914   Click image for larger version
Name:	Taikwong HD Recorder 04.png
post #8 of 15 Old 11-13-2014, 02:16 PM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
A response regarding this new model;
Dear,
Thanks for your advise for our product.
The new model recorder has 3 HDMI 1 DVI 1 VGA Input. 1 HDMI 1 HDMI passby (which can convert DVI VGA to HDMI directly) output.
There are also have audio input to record. It can be used for the record meeting or speech.
Rgds
T.
post #9 of 15 Old 11-13-2014, 03:52 PM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
It looks like it would record NTSC(60hz) but with no usable US tuner it would have to record from a external tuner. Boy some bad grammar in those links, I suppose they just used some translating program but parts just didn't make sense.
It sure would be nice to have something like this available in N. America, and with our TV system but I guess if you could get one shipped it would probably work to record line outputs.....
jjeff is offline
post #10 of 15 Old 11-13-2014, 04:00 PM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
This is available through Amazon;
http://www.amazon.com/Taikwong-Digit...HDD+1080P+HDTV
--Easy using easy recording HDMI signal
--Real-Time & Programmed Time HDMI / AV Signal recording with HDCP technology.The record file is MPEG2-TS format. Can record the Blue Ray Player HDMI 1080I signal. More Signal supported,please see the decription "Resolution Support".
--Support USB storage device up to 2TB (FAT32 File system),Support Playing the machine recorded .ts File by HDRX-420II Only
--Timing Start Up & Shut Down,HDMI & CVBs(AV signal) Input, HDMI UP TO 1080P 24Hz Output ,use H.264 AVCHD M2TS format,Can not output the CVBs(AV signal)
--Any computer can play the recorded .TS file which the software supported. The recorder has no any storage in side,just support outside storage up to 2TB
post #11 of 15 Old 11-13-2014, 04:27 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
This looks a lot like another device from china which a user imported as HDMI recorder a year or 2 ago. I cannot recall the brand but if this records HDCP signals then I am sure it encrypts the payload in the MPEG2-TS packets?
Who is gonna take the plunge and roll the dice on one of these? I'm saving for a house otherwise I would pick it up as another toy to play with.
videobruce likes this.
qz3fwd is offline
post #12 of 15 Old 11-13-2014, 08:48 PM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
The price is at least 3x more than what it's worth. And yes on the "another device from China".
Anyway, another e-mail from the importer/seller (translation optional);
Thanks for your reply,
Our custom need to record the HD lesson video to sell , The recorder is 22.5 x 13 x 6 cm . Not very big. Please see the picture attachment.
We are try to make it to be remote. just like the Ninja . But Ninja can`t recorder the HDMI signal directly , It need software in PC to assistant.
Our product recorder the HDMI directly without any other software. Just click the REC buttom .
You can use our product to recorde the HDMI signal from the Boat GPS, Flight GPS, it`s similar as "black box".
We are doing some picture for your new model machine and the description , it will be release recently.
This one can decryption the HDCP in the HDMI . You can save the HDMI to the storage and make it as the disc. (We have one medel to copy the DVDs to DVDs or Storage).
Rgds
T.
Here is this new version. I think they need a bigger case.
Name:	Taikwong HD Recorder new version.png
post #13 of 15 Old 11-14-2014, 03:05 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
If it really can record HDCP signals from HDMI and is stored in the clear on the hard drive then once the Hollywood companies find out they will get an injunction to block the importation and sale of this device into the United States.....
qz3fwd is offline
post #14 of 15 Old 11-14-2014, 03:44 PM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Shhhhh, I'm not saying anything
Sure sounds like that is the case, with the so called "secret" code......
jjeff is offline
post #15 of 15 Old 02-03-2015, 03:30 PM
Burnerbum's Avatar
Has any else tried this out besides me? So far it's recording everything. I wish I could find a forum to discuss it.
Burnerbum is offline
Reply HDTV Recorders
