DirecTV HR22 problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-30-2014, 05:30 PM - Thread Starter
menetas's Avatar
Liked: 0
Something's wrong with my DirecTV HR22.. It's been working for like four years.. But now it works okay for a while, then it turns off (power save), then it wont turn on again, not from the remote or the front panel either... it sounds like on, i can hear the HDD or something inside, but it just don't work...
I've changed the HDD but it stills have the problem.. All I can do is disconnect it and re-connect it again and wait for all the check, and then it works again with the same way... Works for a while then it wont turn on... It like freezes becomes unresponsive.. I would like to know if someone has a pointer about what could it be..
Thank you!!
menetas is offline
Reply HDTV Recorders
