8300HD starts and stops - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-09-2014, 05:14 AM - Thread Starter
MRoe's Avatar
I have a Scientific Atlanta 8300HD DVR, my subscriber is Cox, Phoenix. I understand it has to turn on maybe once in the middle of the night get updates. But this thing clicks, then you hear the hard drive wind up. then shuts off. It does this couple of times, then stops for awhile. I called Cox, and they say it's normal. It's in my bedroom so it's a real pain at night. I was suppose to have a plain digital cable box in my living room, but instead they gave me another 8300HD unit. Although the DVR portion is not subscribed. But it does not wind up and down. Are there any hidden back doors to the units functions that I can access and maybe turn that part off? Or do I just take it back to a Cox office and demand another one?
MRoe is offline
post #2 of 4 Old 11-09-2014, 11:05 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
If you're running Passport (quite likely), there is a menu function (under power management?) to turn the HDD off when the DVR is switched off.
domino92024 is offline
post #3 of 4 Old 11-10-2014, 04:13 AM - Thread Starter
MRoe's Avatar
It is off, and does shut off when the unit is off, it re-starts and stops, like it's checking something
MRoe is offline
post #4 of 4 Old 11-10-2014, 04:14 AM - Thread Starter
MRoe's Avatar
It is off, but every once and awhile, it starts and stops, like it' checking something.
MRoe is offline
Reply HDTV Recorders
