Using regular desktop drives in PVR? Does it cause an issue? - AVS Forum
post #1 of 1 Old 11-14-2014, 10:59 PM - Thread Starter
alexb76's Avatar
Question Using regular desktop drives in PVR? Does it cause an issue?
I have a Motorola DCX3400 with 500GB hard drive. I'd like to change the internal drive with a larger 1 or 2TB drive and I can find quite a few WD Green drives for cheap.
I know there are special Hard drives (like WD Purple) designed for PVRs, BUT, would using a regular desktop hard drive cause any issues? I am using a regular 7200RPM as an external drive and it works just fine... what's the advice here?
Specifically with WD Green, I can disable the Intelli-park feature and I think it should work ok then, no?
Pioneer Elite Kuro 111FD, Elite BDP-05FD, Elite 72TXV, B&W 805/XTC/M1.
alexb76 is offline
Reply HDTV Recorders
