I thinking of going back to tivo from ceton - AVS Forum
post #1 of 4 Old 01-10-2015, 03:10 PM - Thread Starter
tootal2's Avatar
Has anyone left TiVo for ceton and windows media center and then went back to TiVo?
I want to update my computer to windows 8 but I cant because of the ceton echo.
also don't like using 90 watts of power to record shows when a TiVo does it with 14 watts.
tootal2 is offline
post #2 of 4 Old 01-10-2015, 06:45 PM
Charles R's Avatar
Liked: 228
I don't think you'll find the current TiVo experience much different. Regarding power I have my WMC PC hibernate when not viewing/recording which uses 2 Watts or some such. So overall I think it uses less power than TiVo. Way back when I did the math in the WMC thread linked to in my signature.
As far as Windows 8 I much prefer it to Windows 7 with WMC. I have found it to have a lot less HDMI issues and the various power settings work much better.
Charles R is offline
post #3 of 4 Old 01-11-2015, 08:50 AM
Liked: 281
You don't need Windows 8, and modern low-power PCs draw the same or less than a Tivo especially with sleep factored in. If you're happy with WMC and Ceton there's no reason to switch to Tivo, just get a better PC. Probably costs about the same.
slowbiscuit is offline
post #4 of 4 Old 01-11-2015, 08:51 AM
Liked: 281
Except that it breaks compat with his Ceton extenders, so there's no reason to upgrade WMC if you're using them.
Reply HDTV Recorders
