help / suggestions: cable install without modem/equipment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-17-2015, 01:59 PM - Thread Starter
ljwobker's Avatar
So I'll spare you the sob story, but the Amazon order for my (bring my own) cable modem/TiVo is now NOT going to arrive before the cable tech comes to do the install.
I know in *theory* the installer should be able to verify/validate service to the demarc when they arrive, but I'm also a little worried that when they show up and there is no TiVo or cable modem to actually work with, that's going to be a problem. Anyone have suggestions on what I can do to hopefully avoid a second visit for the install itself?
This is a TWC install in the Raleigh NC area - the home *has* had TWC running at some point in the past, but not for at least 2 or 3 years.
ljwobker is offline
post #2 of 4 Old 12-17-2015, 04:37 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
If it were me I'd reschedule the install, as you said it would be best to have all your equipment onsite before the installer gets there. True it could mean waiting for another onsite visit but if things didn't work after you got your equipment it would probably mean another visit anyway, maybe at your cost
jjeff is online now
post #3 of 4 Old 12-17-2015, 05:01 PM
Dom Di Stroia's Avatar
Quoted: 189 Post(s)
Liked: 97
The on-site technician should have equipment on-hand to test the connection, signal strength, etc.
Also, TWC should supply plenty of remote (e.g.: phone, internet) support.
A/VR: Sony STR-DE598 (6.1 channels)
L/R + C: 2 x Polk Audio TSx220B + 1 x Boston Acoustics CS 26 II
Subs: BIC RtR RtR-12S + Polk Audio PSW110
Surrounds: 2 x Klipsch Reference R-15M + 1 x Boston Acoustics CS 26 II
Monitor: LG 24EA53V-P (Panel: LG Display AH-IPS)
Display: Samsung UN-46EH6000F CS01 (Panel: InnoLux S-MVA)
Dom Di Stroia is offline
post #4 of 4 Old 12-20-2015, 12:35 PM - Thread Starter
ljwobker's Avatar
Well, the tech showed up and tested the signal which was "high" according to him, and he was absolutely adamant that I did not need to plug in the powered splitter/amp that was there from a previous install.
When my modem arrived it wouldn't connect ... until I walked downstairs and plugged that splitter back in. A couple of pretty painful calls to the normal TWC tech support line got my modem up and running, and then one very NOT painful call to the cable card team got the tivo and tuning adapter working.
Sigh. I should have known not to trust the tech who came to the house...
ljwobker is offline
Reply HDTV Recorders
