how to download video from Cisco 9865? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-18-2016, 11:28 AM - Thread Starter
Huskerfan's Avatar
Quoted: 17 Post(s)
I'm switching to the new contour 2 box through Cox Communications and want to be able to keep some of the shows on the old contour box for later viewing.
They say the eSata port is inactive but there's got to be a way to access it. I did it years ago with firewire.
Anyone point me in the right direction?
The box is a Cisco 9865
Husker Nation is strong!
Huskerfan is offline
post #2 of 4 Old 04-19-2016, 09:37 AM
JDLIVE's Avatar
Quoted: 99 Post(s)
Liked: 58
Send a message via Yahoo to JDLIVE
eSata is likely there to expand the capacity with an external drive, it won't help you copy content off the DVR. Your best bet is to use an analog HD PVR and record from the component outputs. There will be a slight loss in quality, but probably not too noticeable.
JDLIVE is offline
post #3 of 4 Old 04-20-2016, 03:06 PM - Thread Starter
Huskerfan's Avatar
Quoted: 17 Post(s)
Thank you. Do you know of any recent programs so sync directly to a laptop? Used to be capvhs but that is old now.
post #4 of 4 Old 04-22-2016, 09:04 AM
JDLIVE's Avatar
Quoted: 99 Post(s)
Liked: 58
Sorry, no. Haven't done any capturing off a DVR for many years. I think there are some tools that you can use on a Mac that will work? I moved over to WMC, much easier when the content is already a file on a PC.
JDLIVE is offline
Reply HDTV Recorders
