Tivo bolt black screen changing channels when HDMI UHD color enabled on HDMI input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-05-2016, 07:54 PM - Thread Starter
djjuice's Avatar
ok so my 4K tv (samsung KS9000) offers a "HDMI UHD Color" mode which states
"An HDMI connection with HDMI UHD Color set to Off supports up to UHD 50P/60P 4:2:0 input signals,
while an HDMI connection with HDMI UHD Color set to On supports up to UHD 50P/60P 4:4:4 and 4:2:2
input signals"
the tivo is set to 4K (2160p 60fps or 2160 fps)
I do have this hooked to a AV receiver Marantz NR1607 but it does the same when going directly to the tv so i don't see that as a cause
i just get a short 1sec black screen when i change the channel, is this the tivo trying to change the resolution?
HDCP 2.2 is enabled
i can turn off the feature and all goes back to normal but since normally this would go through the receiver I would like to have this feature enabled unless i don't need it at all
thank you
djjuice is offline
post #2 of 5 Old 07-06-2016, 07:57 AM
Super Moderator
DrDon's Avatar
Quoted: 868 Post(s)
Liked: 1726
Moved to recorders forum.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #3 of 5 Old 09-21-2016, 11:05 PM
bosorio's Avatar
Quoted: 23 Post(s)
I'm having the exact same problem with my UN75HU8550 and TiVo Bolt.
Did you ever find a solution?
bosorio is offline
post #4 of 5 Old 09-27-2016, 04:14 PM
Bob_Houston's Avatar
Quoted: 70 Post(s)
Liked: 32
Also encountered the same problem when our new Bolt+ is connected to our Samsung UHDTV.
If UHD Color is set to on for the Bolt+'s HDMI port, a black screen is displayed whenever the video is changed due, such as when doing skips forward or backward while a video is playing.
Disabling the UHD Color fixes the problem.
What's surprising is that this is a problem even when the Bolt is displaying TV videos using 1080p - and not just at UHD resolution.
Plus, after watching a video with UHD Color On, the Bolt crashed at the end of the recording - and had to be unplugged from the power in order to get it back.
Bob_Houston is online now
post #5 of 5 Old 01-11-2017, 04:07 AM
gaidin43's Avatar
Issue with Samsung HDMI UHD Color
I am having the same issue with my KU6300 and my tivo bolt. As soon as I turn on HDMI UHD Color and it kills the input from the bolt. I have to reset all picture options go back to stock plug and unplug to get any signal back onto the TV. I have no idea what the issue with this setting. I have HDR+ special viewing mode on movie with a few custom settings, but all the other options are turned off. My bolt is set to 2160 (60 and pass)
Anyone have a fix for this?
gaidin43 is offline
Reply HDTV Recorders
