JVC 30K DVHS Stuck Tape Inside - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-14-2016, 04:46 PM - Thread Starter
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Last night I moved a 30K which had been untouched for at least a year from the office to the bedroom to connect to my desktop.
A tape has been in this problematic deck for a long time and as I recall the last time I used the deck it worked OK.
Last night upon powering on the powerstrip I get the following:
1. Optical out on back near firewire port is glowing red telling me it is getting power.
2. The Digi Picture and S-ET indicators light up but then after a few seconds turn off.
3. A fan or motor spins up for a few seconds. It does not seem to be the large fan bolted to the back which is quite loud. This is a quiet hum.
4. There is no power to the front display at all. Pressing the power button did nothing at all nor the eject / transport controls. Unresponsive to remote control.
5. Tape is stuck inside with now way to eject and the unit is not functioning at all.
There is a HDNet tape in the machine I would like to save. Kinda hard to find as are all DTHeater titles which are getting more scarce each year.
Any suggestions?
Also-does anyone know if the DVE 720p/1080i calibration tapes are D-Theater protected, or are they in the clear and will play on JVC, mits, and panny DVHS decks?
qz3fwd is offline
post #2 of 4 Old 09-16-2016, 11:47 AM
Dude111's Avatar
Quoted: 309 Post(s)
Liked: 518
Hmm when you plug it in the unit should reset if the tape was left in PLAY MODE (Head unit disengages,etc).... Was it plugged in??
What happens when ya press EJECT bud??
Good luck
Dude111 is offline
post #3 of 4 Old 09-18-2016, 12:43 AM - Thread Starter
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Good luck
Totally non-functional. No power on, eject did nothing. I took the top cover off and the service procedure did not work. Unit is in the landfill now. Using a mits deck no and it works perfectly connected to the LG LST-3410.....
qz3fwd is offline
post #4 of 4 Old 09-20-2016, 02:35 PM
Dude111's Avatar
Quoted: 309 Post(s)
Liked: 518
Im sorry you went thru all that..... Ya werent able to save the tape I guess...
Im so sorry buddy
Dude111 is offline
Reply HDTV Recorders
