It's Here - The First HDTV PVR - Zenith HDR230! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 05-27-2003, 04:02 PM
ThumperBoy's Avatar
The real question is if its controller and OS supports drives beyond the 132GB barrier at all.
ThumperBoy is offline
Old 05-27-2003, 05:08 PM
aviators99's Avatar
If it supports two drives, I'll just leave the box open with the drive hanging on something! I'm famous for that.
aviators99 is offline
Old 05-27-2003, 06:13 PM
BillJulyan's Avatar
Quoted: 17 Post(s)
Liked: 43
Originally posted by bertschb
Wooohooo!!!! Nice job.
Did you do a fresh NTFS format to wipe the 120GB drive before you put it in the HDR230? It's hard to believe it 's that easy. If it didn't seem to reformat the drive it must already use NTFS. The next test is to see if it can handle a drive bigger than 120GB.
No, I just took it out of the computer and put it into the HDR230. It probably had about 35 GB of data files on it.
I haven't noticed any problems, yet. I'm going to do some timed recording tonight.
Bill Julyan
BillJulyan is offline
Old 05-27-2003, 06:19 PM
BillJulyan's Avatar
Quoted: 17 Post(s)
Liked: 43
Yes, I thought that might be a problem and that my best chance for success was a 120GB drive. Besides, I already had one.
I'll wait now to see if someone else has success with a bigger drive. I can live with 12 or 13 hours.
Bill Julyan
Old 05-27-2003, 06:33 PM
bertschb's Avatar
That's amazing. Can't wait to see how it works for you as you continue to test it.
bertschb is offline
Old 05-27-2003, 09:58 PM
ptrubey's Avatar
According to the HDR230 sticky thread in this forum, adding extra disk space is as simple as swaping out the drive with a 120GB drive. No formatting, etc. required. There is suspicion (but no one on these forums has tried it yet) that it won't handle drives larger than 132 GB.
ptrubey is offline
Old 05-28-2003, 05:42 AM
BillJulyan's Avatar
Quoted: 17 Post(s)
Liked: 43
I recorded three hours of programming last night. I've played back some of it. Everything looks normal. I think the 120GB drive swap is a success.
Bill Julyan
Old 05-28-2003, 10:25 AM
michaeltscott's Avatar
Quoted: 2706 Post(s)
Liked: 1429
Jaehong Lee reported here that he'd heard that disk size is software-limited to 120GB. As a firmware engineer this seems strange to me, but maybe there's some design issue that I can't conceive of (I'm mightily impressed with their casually-swap-in-new-drive-w/o-formatting capability, so I won't hold this one against them).
The post implies that it's only hearsay, so it wouldn't hurt to try it (he says, not owning one himself ;)). Whomsoever did, could always return the drive, if he carefully bought it from the right place.
-- Mike Scott
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is online now
Old 05-28-2003, 10:53 AM
jeffshome's Avatar
At this point we don't know if the Rom version was updated for the US market. I would be very surprised if Zenith limited the HDR230 to a maximum of 120 gig or about 12 hours. 160 gig drives have been available since Oct. 2001. I don't know how long the design to manufacture time is but you would have to think they were aware of drives bigger than 120 gig at design time. It would seem more costly to have to re-design the controller and OS for > 137 gig than to design it in up front. But maybe it's the old "save a nickel" principle.
jeffshome is offline
Old 05-28-2003, 01:19 PM
ThumperBoy's Avatar
To fully test it with the 120GB, record 12hours and make sure all 12 hours recorded fine.
Old 05-28-2003, 02:20 PM
Liked: 1429
The curious thing is that LG would limit the drive size in the Korean version at all (if, indeed, they did). What was that about? If they did, there may be some serious hard limitations in their software or hardware which might not be so easy to work around.
The only way to find out is to try a larger drive.
Old 05-29-2003, 11:31 AM
mosquito's Avatar
So has anyone popped a drive out and analyzed whether we can view the recordings on a PC or via one of the PC HD cards or something? If it saves the transport stream, you should be able to back it up to DVHS, if I'm not mistaken.
mosquito is offline
Old 05-29-2003, 01:26 PM
ThumperBoy's Avatar
According to the Korean posters, the file format on the hard disk is incompatible with any PC. Someone would have to low level analyze the data on raw sectors in order to write a program to be able to read it and convert it to a TS file.
Old 05-29-2003, 07:11 PM
WTTWSTEVE's Avatar
Sound & Vision noted a timer bug on screen that would not go away. Have any of you guys seen this, and if so, can you get rid of it?
WTTWSTEVE is offline
Old 05-29-2003, 07:37 PM
John Tuohy's Avatar
You just need to hit the exit button from a poster earlier in the thread.
All I ever want is everything
John Tuohy is offline
Old 05-29-2003, 08:48 PM
ThumperBoy's Avatar
A previous poster who has the unit found that pressing exit or just waiting for about a minute and it will disappear.
Old 05-30-2003, 06:14 AM
BillJulyan's Avatar
Quoted: 17 Post(s)
Liked: 43
I decided to see just how much recording I could do with the 120GB drive. It maxed out at 14:53. The approximate time remaining shown on the menu seems to be considerably lower than the actual time available.
I was timeshifting when it hit the max. I got a message that there was no recording space left.
Considering that the original drive showed 8:14 available, I'm happy to get 14:53 out of my upgraded drive. I'm sure the original would have done more than the 8:14 it showed, but I did not fill it up to find out.
To repeat, I used a Western Digital 120 GB 5400 rpm drive that had been in use as drive D: on one of my computers. It was formatted with NTFS and had about 35 GB of data on it. I simply replaced the original with this drive and it worked immediately.
Bill Julyan
Old 05-30-2003, 06:32 AM
bertschb's Avatar
Have you been able to delete sub channels? I can't seem to find a way to do this. We have a couple of sub-channels in my area that are traffic cams and the like and they are a hassle to have to scan through. As well thought out as this unit is I'm surprised I wasn't able to find a way to delete these sub channels.
If I had a spare 250GB drive I would try to swap out the original to see if it handles larger drives. If the estimated disk space is under-reported, this might give us a little over 30 hours. Much more usable.
bertschb is offline
Old 05-30-2003, 10:09 AM
BillJulyan's Avatar
Quoted: 17 Post(s)
Liked: 43
Using the surf feature, you can set it up to stop on the primary channels you want, but with channel up/down it stops on the sub-channels, too.
Bill Julyan
Old 05-30-2003, 10:26 AM
bertschb's Avatar
Thanks. That's the best I could as well. Seems a little goofy that we can't remove sub-channels but that's my only gripe so far.
bertschb is offline
Old 05-30-2003, 12:11 PM
jeffshome's Avatar
I found the Ultra-ATA controller chip on the motherboard. It's Silicon Image's SiI 0649 and features 48-bit sector addressing as described on their web page:
Silicon Image's SiI 0649 is a standalone Ultra ATA/100 host controller designed to accommodate the transfer of large amounts of content-rich data common in today's multimedia applications. The SiI 0649 provides OEMs with a fast, proven interface for hard disk technology. Based on the Ultra ATA/100 interface specification, the SiI 0649 supports a 133 MB/s burst transfer rate and features 48-bit sector addressing, thereby enabling the utilization of drives with capacities greater than 137 GB.
Now if the OS supports 48-bit sector addressing we would be in good shape for larger drives. Did someone say the OS was PSOS?
I am still wondering about support for two drives -- i.e. is the power supply large enough to provide power to a second drive?
Old 05-30-2003, 02:10 PM
JFerg's Avatar
CAUTION about swapping Hard Drives or ANY other modification to your unit.... This voids your warranty and also in most cases releases the manufacturer of liability. This, as mentioned before, can effect your status if there are any firmware updates in the future.
JFerg is offline
Old 05-30-2003, 02:32 PM
jeffshome's Avatar
BAD NEWS! I put in a 180 gig drive and it listed 14 hours 30 mins which is what I would have expected with a 137 gig drive.
Updated: but I was able to record 19 hours 24 minutes.
Old 05-30-2003, 02:40 PM
ThumperBoy's Avatar
That makes sense - the OS probably only supports up to the 137GB limit. So the 120GB drive is the largest practical upgrade, 50% more storage.
Old 05-30-2003, 03:26 PM
poggio's Avatar
A question for you lucky owners: for recorded programs, what are the commercial skipping abilities? Is there only fast forward or are there more sophisticated features like 30-second skip?
poggio is offline
Old 05-30-2003, 03:34 PM
jeffshome's Avatar
MORE BAD NEWS! I also tried adding a second drive but all it saw was the primary drive. I tried both as Cable Select and tried setting one as master and one as slave and vise versa but it only listed the drive space from the drive that was primary.
Old 05-30-2003, 04:15 PM
jeffshome's Avatar
Updated
I installed a 180-gig drive and was able to record 19 hours. I'm still not sure if I am only getting 137 gig from the drive. See posts further down the thread.
Old 05-30-2003, 04:49 PM
jeffshome's Avatar
I attached the original 80-gig drive to a PC but I was unable to read the disk. Fdisk reports two non-DOS partitions. #1 is 40 Mbytes and #2 is 76196 Mbytes. I also tired to mount the partitions under Linux but I could not find a valid file system.
Old 05-30-2003, 05:47 PM
jeffshome's Avatar
I decided to leave the 180 gig in. It gives me 14 hours 30 minutes which is almost 2 hours more than the 120 gig drive and I would be hard pressed to find a 140 gig drive. I'm going to let it fill up using a timeshift to see what the actual recorded time will be.
Old 05-30-2003, 06:05 PM
Thomas Desmond's Avatar
No commercial skip -- just scan at speeds up to 50x. You can edit commercials out of a recording, but that would be a feature more useful for programs you're going to archive (say to DVD at standard definition) than for casual timeshifting.
Thomas Desmond is offline
