Iview 3200 Can't See Edit Shows - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eherberg
post #1 of 7 Old 04-06-2017, 09:56 AM - Thread Starter
spirittoo's Avatar
Liked: 0
Question Iview 3200 Can't See Edit Shows
Well sir ... I am using the program VideoReDo to edit out the commercials ... on the computer I see and can access them. On the Iview 3200STB the folder I created for the edit shows is there, but when I open it nothing. What am I doing wrong?
spirittoo is online now
post #2 of 7 Old 04-06-2017, 10:50 PM
eherberg's Avatar
Quoted: 79 Post(s)
Are you changing the file type to mkv or mp4 or something else during editing? If so - are you then using the 'Movies' option to enter the folder? Using the PVR folder will only show files with the .mts extension.
mdbratch likes this.
eherberg is online now
post #3 of 7 Old 04-07-2017, 10:26 AM - Thread Starter
spirittoo's Avatar
Liked: 0
Arrow Used Default format
I didn't change anything ... just used the default. From mediainfo ... before and after editing ...
General
Complete name : K:\HBPVR\MeTV-03012017-2330.mts
Format : BDAV
Format/Info : Blu-ray Video
File size : 198 MiB
Duration : 9 min 51 s
Overall bit rate mode : Variable
Overall bit rate : 2 809 kb/s
Video
Menu ID : 2 (0x2)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Format settings, picture structure : Frame
Codec ID : 2
Bit rate mode : Constant
Bit rate : 2 491 kb/s
Maximum bit rate : 2 404 kb/s
Width : 704 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.246
Time code of first frame : 02:51:11:01
Time code source : Group of pictures header
GOP, Open/Closed : Open
Stream size : 176 MiB (89%)
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Audio
Menu ID : 2 (0x2)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 129
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Delay relative to video : -601 ms
Stream size : 13.5 MiB (7%)
Language : English
Service kind : Complete Main
Text #1
ID : 65 (0x41)-CC1
Menu ID : 2 (0x2)
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
CaptionServiceName : CC1
Text #2
Menu ID : 2 (0x2)
Format : EIA-708
Text #3
Menu ID : 2 (0x2)
Format : EIA-708
Menu
Menu ID : 2 (0x2)
List : 65 (0x41) (MPEG Video) / 67 (0x43) (AC-3, English)
Language : / English
This is the info on the edit video
General
Complete name : K:\HBPVR_1\Gunsmoke-03022017-1300.ts
Format : MPEG-TS
File size : 895 MiB
Duration : 45 min 16 s
Overall bit rate : 2 762 kb/s
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format settings, GOP : M=3, N=15
Codec ID : 2
Duration : 45 min 17 s
Bit rate : 2 432 kb/s
Width : 704 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.240
Time code of first frame : 00:00:00;00
Stream size : 788 MiB (88%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 192 kb/s
Bit depth : 16 bits
Delay relative to video : 19 ms
Stream size : 62.2 MiB (7%)
Language : English
Text #1
Menu ID : 1 (0x1)
Format : EIA-708
Text #2
Menu ID : 1 (0x1)
Format : EIA-708
post #4 of 7 Old 04-07-2017, 10:49 AM
eherberg's Avatar
Quoted: 79 Post(s)
Except it has changed. Total time is different between the 2 files -- plus you start off with a .mts file, but finish with a .ts file.
post #5 of 7 Old 04-07-2017, 07:57 PM - Thread Starter
spirittoo's Avatar
Liked: 0
Arrow Didn't see that format
I don't see anything in the list with the VideoRedo software that has a .mts format ... I will double check but what if it isn't there?
post #6 of 7 Old 04-07-2017, 08:22 PM
eherberg's Avatar
Quoted: 79 Post(s)
Your first file is from the folder where recordings are stored -- HBPVR. Then your 2nd file is from a folder that you created - HBPVR_1. If that is the folder you are trying to access from the 'Movies' option from the menu - I don't believe it will show the .ts file you created. The manual lists the file types that are playable.
post #7 of 7 Old Today, 08:40 AM - Thread Starter
spirittoo's Avatar
Liked: 0
Thumbs up Oh wow
Ohhhhhhh I see NOW. When I go into the "movie" option, there they are!!! Thank you thank you thank you!!!
Reply HDTV Recorders
