Terk TUNVR1 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By icarah
post #1 of 13 Old 04-12-2017, 11:14 PM - Thread Starter
Quoted: 51 Post(s)
Terk TUNVR1
Hi all, my old Homeworx HW-150pvr died, and I found a tuner with recording capability, the Terk TUNVR1, at a local Fry's Electronics. I purchased it as it seems to be a really recently released product, hoping that the tuner would be decent.
SW Version: Nov 24 2016-11:09:51 -V2
HW Version: ABL7802-R836-A
Can't find any info about this on Terk's website. The manual is quite nice, and it does have very similar menus and recording capability like the Homeworx.
Does anyone know what type of tuner/demod hardware is in these?
Cheers!
tazzarias is online now
post #2 of 13 Old 04-21-2017, 01:10 PM
Liked: 1
I, too, purchased one of these at Fry's. I have had it use for 3 weeks now.
Observations:
The tuner is very good. 1080 video is clear and sharp. It gets all the channels my other TV's have scanned. The built-in signal strength meter shows strong on all transmitters in my broadcast area. I am about 50 miles from the main antenna farms. I use an attic mounted antenna.
The unit gets quite warm. I took it apart to see if I could add some heat sinks to the SMD's only to find that they are already there. The tuner section is fully shielded. The HDMI driver chip is obscured by a large heat sink. There are but 4 IC's on the PCB, the brands of which I could not discern.
The PVR function works fine though the unit needs to be on in order to record if programmed from the EPG menu. This is strange because the unit has a "wake up" timer menu as well. It would be logical to have the EPG record function automatically populate the entries for the wake up timer but it does not. So, I just leave it powered up.
The EPG works well. You can set a recording for just a single instance or multiple (series). However, the unit seems to only make note of the channel and time of a recording. Thus, if you set a series recording for a program that runs 5 days a week, you will still get a recording of whatever was in that time slot on the other days.
It does not seem to be too particular about what type of USB stick is in it. I'm using a Patriot 3.0 32GB which works fine. The recording format is .mts which makes it portable to PC's. MTS files can get large though. I get about 5 hours of record time with my stick. The stick does not have to be dedicated to the PVR as it creates its own directory in which to store recordings. It can be FAT32 or NTFS.
The remote feels cheap but it is functional. Some of the button-command assignments are a little strange but you get used to it.
When I first got it, there was no information (not even a mention) about it on the Terk website. Now it is detailed as a mainstream product. Terk, by the way, appears to to owned by Voxx Intl., maker of a number of well known consumer electronics products.
While there appears to be no firmware upgrade yet, the only reason I could see a need for that is to correct some grammar issues with the OSD and to correct the timer issues as detailed above.
Summation: So far, so good.
RayGuy likes this.
icarah is offline
post #3 of 13 Old 05-03-2017, 02:35 PM
RayGuy's Avatar
Quoted: 823 Post(s)
Liked: 686
Can you hook up something bigger than 32GB stick? Like a 1TB drive, for instance? Need more space!
RayGuy is online now
post #4 of 13 Old 05-05-2017, 04:59 PM
eherberg's Avatar
Quoted: 83 Post(s)
Liked: 24
Yes - but remember there are power limitations if not externally powering the drives. Also know that the larger the drive - the longer the delay in functions starting that use the hard drive. Personally - I think anything over 1 TB introduces an unacceptable delay. I'm actually using a 320 GB hard drive with a Mediasonic box (using a powered hub to avoid the 800 ma limitation with the boxes usb port) where response time approaches flash drive speed.
eherberg is offline
post #5 of 13 Old 06-07-2017, 12:22 PM
tachmn's Avatar
Remote failed after 8 days
I was looking for a way to record ATSC broadcasts but I will never pay a monthly subscription for a program guide that never keeps up with channel changes. (I see that complaint all the time in other threads.)
An earlier post here mentioned the tuner appears to be sensitive. That is critical as I pick up stations from three states. A review for Channel Master CM-7003 on Solid Signal said sensitivity was lousy. So no dice there.
When Fry's had this on sale for $30 recently, decided to take a chance.
The tuner sensitivity appears to match the Digital Stream DTX9950, Zenith DTT901 and Dish DTVPal. So that is good. (Must pick up La Crosse for Packers games.)
The remote is small and kind of hard to use. Plus I don't like using original remotes as the keys wear out. Tried using the pre-programmed universal remotes I have. Didn't find a match. Dug out my old Memorex CP8 remote (remember those?) and taught it a few codes just to get started.
Then 8 days after I got the unit, the original remote started sending a stream of 1s with any key press. 4 sets of 111-111 for the channel. The CP8 still works, and when I teach it a code now, it sends 111-111. Plus the LED that blinks when learning a code blinks for 30 seconds, a lot longer than at the beginning.
Will have to consider my options now.
tachmn is offline
post #6 of 13 Old 06-07-2017, 01:45 PM
ncsercs's Avatar
Quoted: 44 Post(s)
Liked: 36
Wish this was available at Wallyworld.............
Nick
Every day I beat my own previous record for the number of consecutive
days I've stayed alive. - George Carlin - 1996
ncsercs is online now
post #7 of 13 Old 06-07-2017, 04:05 PM
mehdi's Avatar
Available at BuyDig for $50.
https://www.buydig.com/shop/product/TRTUNVR1
-- Mehdi
mehdi is offline
post #8 of 13 Old 06-09-2017, 09:07 AM
Liked: 0
Thanks icarah & tachmn for the details. I'm looking to buy it from Fry's today. Since this seems to be a relatively unknown/new brand, I'm wondering if Logitech Harmony remote can be programmed to control this tuner. Has anyone tried it with Harmony or another universal remote? TIA!
Prabu is offline
post #9 of 13 Old 06-14-2017, 12:28 PM
nclou's Avatar
Quoted: 134 Post(s)
Liked: 129
So I picked this up at Fry's for $30. Hooked it up last night...I think for the price, it seems like a good setup.
It's far from great, the EPG is goofy, the recording is timer based rather than show based, the remote sucks. However, for the price, I'm hoping this works for me.
For recording OTA, I've had a WMC HTPC for a few years, but the PC eventually started quitting on me. It never really played nice with my receiver/TV in terms of waking when switching to the input, etc. anyway, so I always kind of wanted to replace it with something less wonky, although the WMC recording and quality was rock solid.
I really only need to record 1 or 2 shows, and occasional football games, and to be able to pause/timeshift when watching certain event shows like sports or the Oscars etc. It's amazing for such a seemingly simple task, the cost of all the available options quickly rises over $300+, if you're not starting with a PC. And even with a PC, getting an HTPC working just right is it's own hobby, one which I don't feel like taking up again.
If I was a heavy user, recording and watching stuff every night, I think the less than sophisticated operating system would eventually drive me a bit crazy, but for my needs, I think it's going to do the job. At least I hope.
nclou is offline
post #10 of 13 Old 06-17-2017, 06:20 PM
tachmn's Avatar
Actually it does both. Take a look at pages 16 and 17 of the manual.
One "Books" a program from the EPG using the OK key to schedule a recording. The start and end times can still be tweaked to prevent the EPG starting the recording late or ending early. Like start a couple of minutes early and end a couple minutes later. One test recording I booked ended during the credits.
A timer recording is accessed by using the INFO button. It is annoying that the recording process always starts with the lowest channel. Need to go to the desired channel and then set the times.
tachmn is offline
post #11 of 13 Old 06-17-2017, 08:08 PM
nclou's Avatar
Quoted: 134 Post(s)
Liked: 129
I get that, but even if you book the show that way, you're still just booking the time, right? Not the show. So if you book a show, and then they did a special extra episode, or change nights one week, you're not going to get it, are you? That's what I'm trying to say.
I did some test recordings and they were very flawed. Dropped 1-2 seconds pretty frequently...too frequently to put up with. I switched to a 3.0 USB thumb drive and it didn't make a difference. Anyone experiencing this? Any solutions?
nclou is offline
post #12 of 13 Old Yesterday, 11:59 AM
nclou's Avatar
Quoted: 134 Post(s)
Liked: 129
Ok, I think I found the bad recording issue. I had t a USB 3.0 Patriot "Slate" flash drive, and had the same bad recording glitches as when I just tested the Terk out on an old 2.0 drive. Just for the heck of it, I looked up reviews of that stick, and apparently it's trash. According to Amazon reviews, speed is worse than most 2.0 flash drives. So I returned it and exchanged it for a Samsung 3.0 low profile drive.
The test recording I did with the new flash drive was rock solid perfect. This machine is a bit goofy, but for the price, it might work out great.
nclou is offline
post #13 of 13 Old Today, 11:07 AM
tachmn's Avatar
I misunderstood the issue as I have never owned a DVR that requires a subscription. So no idea what scheduling capabilities a subscription provides (i.e. book a show independent of the date/time).
Without a subscription, the Terk is totally dependent on the EPG the station sends for scheduling (it doesn't even have an internal clock). And yes, booking from the EPG is just an easier way to book the time. Think of it as a digital VCR, where the recording can be scheduled once, or repeated daily or weekly. But no intelligence to determine what it is recording.
tachmn is offline
Reply HDTV Recorders
