LG LST-3410A Review and Discussion - Page 241 - AVS Forum
post #7201 of 7209 Old 03-16-2014, 07:23 AM
Jan J's Avatar
Just dropped by to say "HI"... Wife still using 3 of 4 units... I've experiment using 4th to feed Component HD to a capture system.... and it works!
Looking for a 1939 Indian Motocycle
Jan J is offline
post #7202 of 7209 Old 10-18-2014, 08:31 AM
Jan J's Avatar
3 of 4 in use every day... 4th used only once or so a month....
Did encounter something odd... Bailed out of record on Ken Burns OTA program on PBS.... but then found out all cable boxes switched on H & V copy protection on same program.... After the show was over, all returned to 'normal'.... So I think there was something in the OTA stream that burped the recording.
Happened to me, and another on same OTA recording, at same time! (Clock froze at same time).... Multiple 3410a firmwares, so it must follow something in OTA signal... But I'm not sure what...
Jan J is offline
post #7203 of 7209 Old 12-05-2014, 06:49 PM
kcgr's Avatar
I've just been a lurker on this thread, but I now have a reason to post a 'big thanks' to Jan J. My unit was doing the "Hello" error, so I found the old posts on replacing the C129 cap, and I'm back in business. My soldering skills weren't the most artistic, but who cares... the electrons are flowing now. Thanks again for your posts. I have the other caps just in case, but I'll wait until I need to do 'em, since the unit is lightly loaded.
kcgr is offline
post #7204 of 7209 Old 12-06-2014, 07:27 AM
Jan J's Avatar
Thanks kcgr for your kind words....
Yes, I posted Mods as I stumbled across them....3 of 4 units are still in use each day... . 2 of the 4 have larger hard drives in them, one a PC drive, rather than the specified Quickview drive.
The Power supply mods I've done to about 24 units now, Not One has acted up since.
Back when TVG was being transmitted on CBS cable channels and it was locking up the 3410a, removal of the TVG cap prevented the 3-4 day lockup....
Thank goodness they left the old fashioned VCR Record setup menu in the box, eh????
Way back when, when I had a computer with W98 on it, I was upgrading 3410a firmware..... V1.17 was the last version they made, and I routinely upgraded 1.12, 1.14, and 1.15 to 1.17 on 'many' units...
Has anyone found a program that works under W7 for that could transfer binary files out a serial port?
Jan J is offline
post #7205 of 7209 Old 12-06-2014, 08:22 AM
Stanton's Avatar
Quoted: 26 Post(s)
WinSCP: just used it in a training class this week to transfer binary files (basically a GUI based FTP).
Yamaha DSP-A1 Integrated Amp
(4) Polk Monitor 10B's w/SoniCaps and Mills resistors (R/L F/R)
(2) Polk Monitor 4's w/peerless tweets (dual centers)
B&O TX2 Turntable
Nakamichi Cassette Deck 1
Pioneer CLD-99 Elite LD
Samsung BD-P2550 Blu-Ray/DVD
Princeton AF3.0HD Monitor
Optoma HD65 Projector
Stanton is online now
post #7206 of 7209 Old 12-07-2014, 05:47 PM
Jan J's Avatar
Thanks for that information...
Jan J is offline
post #7207 of 7209 Old 01-10-2015, 08:13 PM
Jan J's Avatar
Question came up....
Has anyone tried a SATA drive with the 3410a?
What Sata to PATA interface did you use?
Jan J is offline
post #7208 of 7209 Old 01-10-2015, 08:37 PM
joecass's Avatar
Quoted: 14 Post(s)
Yes,,, I installed a WD 2500AAKS 250GB several years ago using a generic IDE to SATA adapter purchased on Ebay for about $4. Works very well, also works in older computers without SATA connections. With this adapter, no need to worry about Master/Slave configuration unless you're using more than one drive
Name:	IDE to SATA.jpg
ID:	471961   Click image for larger version
joecass is offline
post #7209 of 7209 Old 01-10-2015, 08:51 PM
Jan J's Avatar
Thanks much for this information.... Fantastic to hear that it worked fine! Will pass it on...
Jan J is offline
Reply HDTV Recorders
