LG LST-3410A Review and Discussion - Page 244 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #7291 of 7302 Old 03-30-2016, 02:06 PM
joecass's Avatar
Quoted: 72 Post(s)
Originally Posted by Jan J View Post
It's been a while since the 3 DVR's have been left 'on' 24/7.
Wife has been using them to augment her time shifting, with OTA and QAM (from Cable) feeds.... We've encountered one Cable Channel (Fox) on QAM channel 117.3 that will go through the motions of recording an hour show, and when it gets time to playback the recorded time is randomly less than an hour, and entire show is not recorded. This happens on all 4 units, (I left one stock with 120Gb Drive, as well as two with 1TB Sata's, and one with 330GB Quickview).... For this reason, I'm thinking it is something encrypted into the feed.
Other than that one channel..... Everything is working fine...
For the past 8 + years, Fox 5 has given me the most trouble as far as reception goes.... that includes straight from a cable box, the QAM wall feed, and OTA. It might be something in the feed, but from what I've experienced, it's a loss in signal quality, even if only momentary.
Here in New York, Fox 5 and My 9 share the same OTA frequency. There are two sub-channels on Fox 5, and three on My 9, which to me translates into in an inadequate signal.
When I had my LG hooked up to QAM, Fox 5 gave me the most problems. If all your machines react the same way, then I would suspect it's the fault of the broadcaster. BTW, I also have two LG HD tuners from the same era as the 3410A, had the same reception problems with them on Fox 5.... namely the signal would actually drift to a sub-channel, with Spanish-language programming. I used the LG tuners in conjunction with DVD recorders; day after a recording, instead of the.... at the time, interesting programming, I'd get some off-the-wall show recorded instead of Fox 5. This used to drive me crazy.....
joecass is offline
post #7292 of 7302 Old 03-30-2016, 06:00 PM
ebo
ebo's Avatar
Quoted: 58 Post(s)
I vaguely recall that early MyHD cards had trouble with Fox stations. It had something to do with a difference in the way Fox fed programming to its affiliates compared with how everyone else did it. The developers eventually came up with a software fix but I don't remember any details.
ebo is offline
post #7293 of 7302 Old 03-30-2016, 11:49 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
splicers? I recall fox being problematic also.
qz3fwd is offline
post #7294 of 7302 Old 06-25-2016, 08:37 AM
Jan J's Avatar
Quoted: 38 Post(s)
I used to do some free lance work at Fox in Chicago... They used a 'splicer' and it was noisy and glitchy as all getout... compared to a HD switcher and and ATSC encoder.... At first they had weather on sub channel, but then removed it...
Regarding the LG DVR's:
The 2x 3410a's with TB drives (Sata to IDE converter) and left 'on' full time have been doing a great job for the wife.
We encountered an issue with all units Not decoding a channel, (Black with audio displayed) but that was fixed by a power cycle. Doesn't follow a modified unit, so it must be something it 'saw' off the local OTA or Cable channels..... and a reset returned all to normal operation...
Looking for a 1939 Indian Motocycle
Jan J is online now
post #7295 of 7302 Old 12-06-2016, 05:20 PM
Jan J's Avatar
Quoted: 38 Post(s)
It's been about a year since I added Sata to IDE converters and 1TB drives to 2x 3410a's...... Due to the power up FAT read timeout issue, they have been LEFT POWERED UP since this modification....
It's been about a year since this has happened.... Both units have worked flawlessly., recording and playing back every timed recording that was programmed... I restarted one when it locked up on a Fox channel... and refused to decode a HD Channel (Black), but that only happened once in the year's time... Temperature of the units are no warmer than when they powered up and down again (remember years ago I added taller 'feet' below the units, and re-capped the power supplies)..
So of the 5x 3410a's I have had, for what, 13 or so years? 4 are still fully operational!
2x have 1TB drives with >100 hours of HD recording time.... 1x has a 330 Quickview drive, and one has a stock 120 drive.
The 5th one was given to me with something spilled in it by a user here... I cleaned it as best as possible, and even got it going for a couple months, but eventually the liquid shorted traces under a large chip, rendering the unit inoperative... This unit was stripped for usable spare parts, with parts of motherboard removed and given to users here; The Power Supply was updated with all mods I found necessary; The Front Panel, and Hard drive being kept for spares.
I'm amazed in the longevity of this unit!
I have multiple stock hard drives, one of which would be made available to anyone here for free as long as you provide postage to get it from here to you...
joecass likes this.
Jan J is online now
post #7296 of 7302 Old 12-07-2016, 07:55 AM
Stanton's Avatar
Quoted: 1458 Post(s)
Liked: 762
Been using mine to record Johnny Carson off of Antenna TV the last several months...and watch the occasional prime-time show when the DVR is busy (great HD picture). Still have the original 120 Gig IDE HD!
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is online now
post #7297 of 7302 Old 12-07-2016, 02:15 PM
joecass's Avatar
Quoted: 72 Post(s)
Mine is still operational, but I stopped using it last spring. My other DVRs are more efficient at fast forwarding or skipping through commercials. It's still plugged in, though, in case I need a spare recording device.
joecass is offline
post #7298 of 7302 Old 01-24-2017, 04:19 PM
Marc Alexander's Avatar
Quoted: 1354 Post(s)
Liked: 1017
I have a 3410 in mint condition that has been in storage since 2005 (original 120GB hard drive, 3.31 FW, remote, box, etc.). What's the ~street value of one of these today? I'm guessing not much.
Marc Alexander is online now
post #7299 of 7302 Old 01-24-2017, 05:49 PM
joecass's Avatar
Quoted: 72 Post(s)
Last time I saw one for sale on Ebay, it was around $125 or so. Not many sellers over the years that I've seen, and very few diehard LG enthusiasts. I would ask $125 and take it from there.....
Marc Alexander likes this.
joecass is offline
post #7300 of 7302 Old 01-30-2017, 05:04 PM
Jan J's Avatar
Quoted: 38 Post(s)
I've got 4 or 5 120Gb Seagate Quick-view Hard drives that were tested good when removed..... (Stock drive from LG 3410a) and they've been sitting in my spare stock for years.....
If anyone has any interest in acquiring a spare hard drive... Here's a way you can get one --- nearly for free.... All you'll have to do is send me a proper Disk shipper with enough return postage to get it back to you.... and I'll be happy to give you one for free.... (I'm going through my spare stuff, and with all the upgrades I've done, I really have no use for 120Gb drives in the 3410a...
So if you ever wanted a spare, here's a way to get one nearly free!
Please note that the Quick-view drive does not attempt to correct when it encounters an error... So these drives WOULD NOT be a candidate for use in a computer..... !
Send me a private message, and I'll pass along my mailing address... (PS. I retired, and am not in Illinois any longer)
Jan J is online now
post #7301 of 7302 Unread Yesterday, 11:30 AM
Jan J's Avatar
Quoted: 38 Post(s)
FYI:
Well... Here I thought I had modified all the LG3410a's that I own.. (4)... but I didn't!
Last week I received the "HELLO" Boot Loop!!! on one unit....
I thought I had replaced C129 (10uf cap) on this unit... No, I hadn't.... and it finally dried out!!!
Replaced C129, and unit happily booted and is back to full operation again!!!
Jan J is online now
post #7302 of 7302 Unread Today, 06:47 AM
Stanton's Avatar
Liked: 762
FYI:
I guess this will happen to me...someday...which is why I keep this thread bookmarked!
LG 65EF9500 4K OLED
Reply HDTV Recorders
