The Official Dish Network DVR-921 Support Forum! - Page 5 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #121 of 121 Old 05-27-2004, 04:41 PM
Joe Q's Avatar
Originally posted by dalzar
Is your HD TiVo compliant with any sat. feed or only D*TV? I guess my real question here, is therea way to use TiVo which appears to be an intelligent DV recorder with a separate tuner? What is the connection? Can I still go DVI for HD?
Like the other poster said. The HD TIVO only works with Directv.
It is all tied up in the sat transmission format that the receiver understands.
DISH is a combo of 4psk and 8psk (If I recall correctly) but being new to Directv, I have not had a chance to check what it's tarnsmission format is but I KNOW it is incompatible with DISH's.
The DISH 811 and 921 do DVI and the Directv HD TIVO do DVI.
If you are looking for an inexpensive way to get a DVI connection from an OTA HD tuner, look into the MYHD card.
Joe
Joe Q is offline
Closed Thread HDTV Recorders
