Photos of the inside of the LG LST-3410A - AVS Forum | Home Theater Discussions And Reviews
Old 02-17-2004, 11:29 AM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Hi,
Here are 3 photos of the inside of the LST-3410A. As you can see, it uses an UDMA-100 interface on the hard drive, not S-ATA. The Seagate drive is an ST3120025ACE.
So far, the only disappointment with this box is that they didn't put a Svideo input for SDTV.
Notice that the UDMA cable is, by standards plugged in backwards. The blue end of these cables are normally plugged into the mother board, and the black end goes to the drive.
Here is the 1st photo.
Al
MORE PHOTOS ON PAGE 2
BOBCAT is offline
Old 02-17-2004, 11:34 AM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Here is the 2nd photo. Notice that the power cable runs over the main board voltage regulator, and blocks the cooling fins. A zip strap around the cable to the transformer on the power supply will pull that cable clear of it.
BOBCAT is offline
Old 02-17-2004, 11:38 AM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Here is the 3rd photo of the vertical board that plugs into the main board. It has the IR jack on it to connect the IR "G-Link" sender to control the cable box or other devices.
BOBCAT is offline
Old 02-17-2004, 11:43 AM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Hi All
If there are any other views that you would like, let me know, and I will post them.
Al
BOBCAT is offline
Old 02-17-2004, 12:04 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Now that I know for sure what interface that this unit uses, will look for the best price for a Seagate 200GB drive. I know that there are larger drives out there, but none come close to Seagate for being quiet, and not becoming noisy after a year of 24X7 use. I have used WD drives in my TiVo, and after 8 months they are starting to whine. After more than a year, my 1 TiVo with the Seagate drive is as quiet as the day I put it in. The best price that I have found so far for a 200GB 7200rpm Seagate drive Is mwave.com under 140. So will order one out.
Good luck to all of you with your upgrades, Should be a very simple thing to do.
Al
BOBCAT is offline
Old 02-17-2004, 03:35 PM
spike4's Avatar
Thanks Al
spike4 is offline
Old 02-17-2004, 10:03 PM
nyg
nyg's Avatar
Originally posted by BOBCAT
Hi All
Al
Can you please post a picture of the rear view of the unit (outside)? I've been considering purchasing this item after reading the review thread here.
nyg is offline
Old 02-17-2004, 10:35 PM
Jasmo's Avatar
Bobcat,
If you hurry, you can pick up a 200GB Seagate (7200rpm) drive from Compusa for $99.99 (after a $70 rebate from Seagate). They did have a "penny" shipping special for President's Day but I'm not sure if that is still going on or not. Still, a pretty good deal. Check it out!
Seagate 200GB Hard Drive Sale
Jasmo is offline
Old 02-18-2004, 02:29 AM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Jasmo,
Thanks for the info, I already ordered from tiger direct. They matched mwave price, and no tax.
Al
BOBCAT is offline
Old 02-18-2004, 02:36 AM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
amelie,
Will not be able to post the photo until Saturday as it is up and running now. I won't be pulling it out of service until my 200GB drive arrives Friday. will post the photo then.
The odd thing is that there is a grill for a fan, but no fan installed inside. guess that LG changed there mind on installing it.
Al
BOBCAT is offline
Old 02-18-2004, 11:55 AM
Tulsa1's Avatar
Liked: 71
Does the time shift on this unit function better than the Zenith HDR230?
Do you have to select the time shift at the beginning of the show to go back in time?
Obsessed for the ultimate PQ
Tulsa1 is offline
Old 02-18-2004, 03:56 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Tulsa1,
Its the same as the HDR230, You have to start it. The hard drive does not spin up until you need it. Its not like a TiVo where it is recording a 30min block of video all of the time.
Al
BOBCAT is offline
Old 02-19-2004, 06:49 AM
Tulsa1's Avatar
Liked: 71
Thanks Al,
Looking forward to the HD Tivo for sure.
No sense in buying another box till then.
Six weeks and counting.
Cheers,
Martin
Tulsa1 is offline
Old 02-19-2004, 09:58 AM
orbitzboy's Avatar
Has anyone tried to replace the IDE cable with a dual to plug in 2 drives? Yes, looking at the picture there clearly isn't room in the case for the second, but that's where a little creativity comes into play. I was just curious if the unit would even see the second drive
orbitzboy is offline
Old 02-19-2004, 10:01 AM
orbitzboy's Avatar
Oh yeah.
For those replacing the drive with a larger capacity seagate drive, make sure you connect the drive to a PC and run seatools on it BEFORE you install it into the LG. Seems Seagate has acoustic management turned off by default in the 200gb version, and there is a very big sound difference with it on/off.
Old 02-19-2004, 10:50 AM
Stanton's Avatar
Quoted: 1411 Post(s)
Liked: 741
I don't see any fans in the pics, so why worry about the cable runs. Am I missing something?
BTW, I have one of these (and it's doing just fine).
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is online now
Old 02-19-2004, 11:20 AM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
so why worry about the cable runs, am I missing something?
Stantan,
The cable resting on top of the heat sink will prevent the proper cooling of the voltage regulator, so the device will run hot. This will cause premature failure. Thats what you are missing!
Al
BOBCAT is offline
Old 02-19-2004, 11:25 AM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
orbitzboy,
Thanks for the tip. UPS just delivered the drives, so will run the utility before installing them.
Al
BOBCAT is offline
Old 02-19-2004, 12:04 PM
umr
umr's Avatar
Quoted: 39 Post(s)
Liked: 77
Stantan,
Al
How do you know it will run too hot? I have no experience with designing these devices. I am curious what your basis is for this statement. Does the current draw effect the themal load? Are specific air flow paths required?
umr is offline
Old 02-19-2004, 01:37 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
umr,
I did not post this to discuss thermal dynamics. In short, the cooler the device runs, the better off it is. Voltage regulators run hot by nature. They need to dissipate their heat freely. Heat rises. If the top of the heat sink is covered it will not dissipate the heat at the calculated dissipation rate for the surface area of the heat sink. The circuit designer didn't just grab a heat sink out of a box. He calculated the heat sink size by knowing the current draw, and how much heat the device will dissipate at that level. That will tell him how much surface area is needed to dissipate the heat in free air. In blocking the air flow, the operating temperature goes up, and may exceed thermal operating range of the device. The device fails.
A 2 cent zip strap gives a better chance of many years of continued service.
Al
BOBCAT is offline
Old 02-19-2004, 02:16 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Hi orbitzboy,
Went to the seagate site. They have a seatools desktop program that runs a test on the hard drive, but no acoustic management utility.
There are 5 utilities listed , but nothing for acoustic management.
Could you tell me where you found this utility?
Western digital has this utility, but I haven't seen one for seagate in the past.
Al
BOBCAT is offline
Old 02-19-2004, 03:21 PM
nyg
nyg's Avatar
amelie,
Great, thanks! I'll look for it then.
nyg is offline
Old 02-19-2004, 03:36 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
amelie,
The drives arrived today, so will be replacing the drive tonight. Will try to get the photo up in the next few hours.
Al
BOBCAT is offline
Old 02-19-2004, 04:13 PM
tji
tji's Avatar
FYI - I have found the new Maxtor drives to be quiet. They have fluid bearings, like the Barracudas. I have 5 Barracudas, of various sizes, that I have been very happy with. I gave the Maxtor a try after reading positive reviews, and because it was only $177 (before $30 rebate) for a 250GB drive.
We'll see if it remains quiet after long term usage.. I've only had it for about 3-4 months.
tji is offline
Old 02-19-2004, 04:16 PM
umr
umr's Avatar
Quoted: 39 Post(s)
Liked: 77
[B... The circuit designer didn't just grab a heat sink out of a box. He calculated the heat sink size by knowing the current draw, and how much heat the device will dissipate at that level. That will tell him how much surface area is needed to dissipate the heat in free air. In blocking the air flow, the operating temperature goes up, and may exceed thermal operating range of the device. The device fails.
Al [/b]
I agree it is not a bad idea to add a strap. I thought with your ham radio hobby you might have been involved in designing systems like this and have specific insight on the probability of failure due to restrictions in convective air currents.
Hoever, it sounds like you are speculating on the temperature rise being high enough to impact component life.
I look forward to hearing about your drive upgrades.:cool:
umr is offline
Old 02-19-2004, 04:42 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
umr
Here is a photo of the zip strap in place.
BOBCAT is offline
Old 02-19-2004, 04:50 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
amelie,
Here are 2 photos of the rear.
Photo 1
BOBCAT is offline
Old 02-19-2004, 04:52 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Here is photo 2. Notice that there is a grill opening that looks like a fan grill, but no fan inside.
BOBCAT is offline
Old 02-19-2004, 06:23 PM
nyg
nyg's Avatar
amelie,
Photo 1
Thanks for the pictures... exactly what I was looking for. I too, am interested in hearing how the drive upgrade goes.
nyg is offline
Old 02-19-2004, 06:50 PM - Thread Starter
BOBCAT's Avatar
Quoted: 88 Post(s)
Liked: 78
Hi amelie,
The drive upgrade was as easy as 1,2,3.
Pulled the 200GB drive out or the package and set the jumper for a master drive. Unplugged and removed the old drive. Installed the new drive.
Powered up the 3410 and checked the total recording time. Now have 21hrs HD or 40 hrs of SD. Didn't need to format the drive, as it does it automatically.
Did not loose my weekly recording schedule or the TV guide info, so this info must be stored in flash memory on the main board.
Al
BOBCAT is offline
