Anyone want to speculate on Alans appetizer??? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #121 of 127 Old 06-04-2004, 04:33 PM
Babula's Avatar
Interesting Who Is for Skyseeker:
http://www.enom.com/domains/whois.as...e=skyseeker.tv
The World Is Not Flat!
Babula is offline
post #122 of 127 Old 06-04-2004, 04:34 PM - Thread Starter
Kipp Jones's Avatar
Alan,
how soon are we talking about the official press release?
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #123 of 127 Old 06-04-2004, 04:38 PM
Chris Gerhard's Avatar
Originally posted by jacmyoung
What I don't understand is Allan said this is not a firewire based solution yet all the playback devices he mentioned share one thing in common, firewire. Even if firewire is only used for playback, can you claim the system is not firewire based?
I didn't see that firewire was needed to playback the recording. Alan is making recordings with this new device and can play it back glitch free with a JVC HM-DH3000U, MyHD, LG HD PVR, and JVC HM-DH40000U so the recordings are made on a PC and transfered via firewire to three of those devices. I still don't know how the recordings are made since it isn't by using firewire but so far it sounds like it will be the current winner for archiving HDTV when introduced. What is the input source for the recording?
Chris
Chris Gerhard is offline
post #124 of 127 Old 06-04-2004, 05:21 PM
Glimmie's Avatar
Quoted: 760 Post(s)
Liked: 625
Don't overlook the good old parallel port. Every PC still has one and it can suck in the MPEG transport stream at ease. Such a modification to the receiver would be minimal, you just tap (and hopefully buffer) the 8bit stream and clock.
Such a mod would be higly reliable and low cost.
Glimmie is offline
post #125 of 127 Old 06-04-2004, 05:57 PM
thomopolis's Avatar
Semi-stupid question.
I've never bought a modified receiver before. Do you generally have to have the receiver that is being modified, or does the modifier ever buy a bunch and then sell them as a unit?
Trying to figure out how to get hold of an out of date receiver if these become short supply on ebay after the announcement.
tom
thomopolis is offline
post #126 of 127 Old 06-04-2004, 06:31 PM
tom
As far as I know the only receiver modification for recording HDTV is the 169time mod. You can buy a modified receiver or send your receiver in to be modified. So yes apparently he bought a bunch of receivers to modify. I am tempted to buy one of the receivers that will work now and be ready since this sounds so good. It isn't clear yet that the receiver has to be modified but it sounds like that must be the case. I can't imagine it is possible with component, DVI or VGA output so a parallel port modification might be the answer.
Chris
post #127 of 127 Old 06-04-2004, 06:51 PM
Ken H's Avatar
http://www.avsforum.com/avs-vb/showt...hreadid=409442
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread HDTV Recorders
