SA 8300 HD with DVI & DVR - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 1154 Old 12-29-2004, 09:55 PM
DBFullert's Avatar
I've had my SA8300HD DVR for less than 36 hours. As of this afternoon it was working perfectly, although this evening it has begun misbehaving. It will work for roughly 10 seconds, then the box will display the message "Er.40" and will lock up. I was wondering if anybody knew what the system error codes meant so I could begin to troubleshoot (or return box -- TW technical support said they didn't know and don't have any in stock to swap for a good one). Thanks!
DBFullert is offline
post #542 of 1154 Old 12-30-2004, 05:24 AM
hookbill's Avatar
No question, this box has problems. Call your cable company and get a new one.
MY NAME IS NOT BILL (but you can call me hook)
hookbill is offline
post #543 of 1154 Old 12-30-2004, 07:29 AM
AlbanyHDTV's Avatar
Originally posted by davehancock
As I recall, some of the people on our local RochesterHDTV Forum had this problem with an earlier version of SARA. (might have been 1.85.14.1) that went away with an upgrade. We are at 1.85.17.3 now and no longer have the problem.
Albany NY TWC now has SARA version 1.85.17.3.
And, HD PPV appeared on channel 1800. More about this here.
Currently, the only offering is Africa (IMAX) HD for $4.95. Rated G, 42 min. runtime.
AlbanyHDTV is offline
post #544 of 1154 Old 01-02-2005, 04:50 PM
bent98's Avatar
Quoted: 21 Post(s)
Anyone know if the 8300 has an internal test pattern, like HDnet has at 7:00. I am switching to cablevision and they dont offer HDnet yet. Would like to calibrate some how.
bent98 is offline
post #545 of 1154 Old 01-03-2005, 03:42 AM
hookbill's Avatar
No there is no internal test pattern, however you can calibrate it pretty close by getting purchasing a copy of Digital Video Essentials. It will run between 15-20 bucks on Ebay. I used it initially to calibrate my HDTV and then used HDnet and there really wasn't too much difference. Some of the alignment on my set was changed when I used HDnet's patterns but the color and black areas remained the same.
hookbill is offline
post #546 of 1154 Old 01-05-2005, 08:02 PM
CWS
CWS's Avatar
Anyone notice the sound skipping out on dark screens, like the credits? I had that problem at one time with the SA8000HD, but I thought it had been fixed - maybe not. I just saw it again on the 8300 at the end credits of "Monster", that I had recorded. Bummer
CWS is offline
post #547 of 1154 Old 01-06-2005, 04:15 AM
bent98's Avatar
Quoted: 21 Post(s)
I am assuming you mean cailbrate TV with DVD player.
bent98 is offline
post #548 of 1154 Old 01-06-2005, 04:16 AM
hookbill's Avatar
I'll bet that wasn't your 8300, but probably the broadcast itself. It was happening to me last night while I was watching "Lost" for about 25 minutes of the show. I could see as they started to fix it they switched to 480i then back to 720p.
hookbill is offline
post #549 of 1154 Old 01-06-2005, 04:23 AM
hookbill's Avatar
Yes. Many people have done this. I found out about it on these boards.
hookbill is offline
post #550 of 1154 Old 01-06-2005, 10:04 AM
CWS
CWS's Avatar
Possibly so, but the whole movie was fine until the credits. I'll try to find another one with dark credits to test the theory.
CWS is offline
post #551 of 1154 Old 01-06-2005, 01:11 PM
AlbanyHDTV's Avatar
Time Warner Orders DVR Sidecars'
Regarding external hard drives for extra storage capicity.
new thread at: http://www.avsforum.com/avs-vb/showt...hreadid=491661
NOTE: The moderator merged my thread with another, so I updated the link.
post #552 of 1154 Old 01-06-2005, 06:34 PM
vegggas's Avatar
I confirmed this with the SA reps at CES today. They said that two manufacturers would be making announcments today.
vegggas
vegggas is offline
post #553 of 1154 Old 01-06-2005, 06:50 PM
DoubleDAZ's Avatar
Quoted: 339 Post(s)
Liked: 397
vegggas
And just where is Cox in all this?
Cheers, Dave
DoubleDAZ is online now
post #554 of 1154 Old 01-06-2005, 07:26 PM
vegggas's Avatar
Who knows at this point. I was told the SATA interface is open here in Vegas, and if I could find a compatible drive, it should work. Now that I know, I may be heading to FRY's to pick one up to start testing. I still have a few more days at CES first... I will be posting another SA thread about all their new units coming soon in the recorders section.
vegggas
edit: Scientific Atlanta's new stuff at CES
v
vegggas is offline
post #555 of 1154 Old 01-06-2005, 08:16 PM
DoubleDAZ's Avatar
Quoted: 339 Post(s)
Liked: 397
Cool, I look forward to the new thread. I'll bet you're having a good time at CES, as always.
Cheers, Dave
post #556 of 1154 Old 01-07-2005, 07:22 AM
MarketingProf's Avatar
Was that thread pullled or something? Just tried to go there and it wouldn't let me access it.
Marketing Professor
Music, then Movies...
MarketingProf is offline
post #557 of 1154 Old 01-07-2005, 08:41 AM
vegggas's Avatar
vegggas is offline
post #558 of 1154 Old 01-07-2005, 03:50 PM
TheMostToyzWins's Avatar
vegggas
v
Finding a compatible drive is easy, finding the special SATA 2 - SATA 1 cable is another story. I can't find the link, but there was someone here that was special ordering one to see if it works. I don't remember seeing a followup with results.
I have had the drive and external enclosure for three months, but have yet to find a cable.
Let us know how it turns out for you.
TheMostToyzWins is offline
post #559 of 1154 Old 01-07-2005, 06:03 PM
vegggas's Avatar
I have determined than not just any SATA drive will work. The drives mentioned are optomized for video streaming and working with the PowerTV software. The drives are NOT PC COMPATIBLE (I Know, not Legally Compatible, but it could probably be reformatted etc.). Both Maxtor and Seagate are selling these directly to cable companies first, then probably a USB version directly to consumers for other STB's.
The QuickView Expander drive will eventually be sold in retail, although Maxtor has not set a date for a retail launch and has not determined an estimated retail price.
From http://www4.maxtor.com/en/products/a...w_info_req.cfm
The new QuickView Expander drive leverages the core technology of Maxtor QuickView consumer electronics (CE) hard drives, which power a high share of today's DVRs worldwide. Different than a standard PC hard drive, Maxtor QuickView CE drives are designed for streaming media applications and offer exceptional performance and advanced features that enhance the digital entertainment experience.
The Serial SATA2 Spec also calls for sustained 3.0Gbps transfer rate from the drive surface and sustained 300Mbps transfer. The SATA2 speck goes down to the block transfer and will require SATA2 to SATA2 compatibilty to do this. Using a SATA1 device will not work to meet SATA2 standards, but SATA2 devices are compatible with older SATA devices. You could compare it to USB 1.1 vs USB 2.0. A USB 1.1 device will never meet the USB 2.0 spec and transfer rate.
vegggas
vegggas is offline
post #560 of 1154 Old 01-07-2005, 06:08 PM
Pradeep's Avatar
The Serial SATA2 Spec also calls for sustained 3.0Gbps transfer rate from the drive surface.
vegggas [/b]
Maximum theoretical transfer of SATA 2.0. No drive is getting even close to 3Gbps, let alone SATA 1's 1.5Gbps.
I don't see why a standard SATA drive won't work in the Maxtor enclosure, given it uses a standard Maxtor SATA 1.0 drive in the 8300HD. Of course no telling what kind of protections they've put in place.
Pradeep is offline
post #561 of 1154 Old 01-11-2005, 01:33 PM
BlackwaterStout's Avatar
Anyone know if this unit can simultaniously output signals from both HDMI and from composite?
I am thinking about getting a DVD Recorder and would like to capture shows in real time as I watch them. I've got my HDMI running to my TV and plan on using the svideo output on my 8300 to go to the DVD recorder and then from the DVD recorder I'd go back into a composite jack on my TV. I know I can do this with the record to VCR function, but it live output come out of both HDMI and composite at the same time?
BlackwaterStout is offline
post #562 of 1154 Old 01-11-2005, 02:50 PM
Ash Sharma's Avatar
Quoted: 646 Post(s)
Liked: 509
Yes, I am able to record from s video on my Tivo and watch H D through H DMI
Ash Sharma is online now
post #563 of 1154 Old 01-12-2005, 08:04 AM
hookbill's Avatar
I think I understand that software distribution for the 8300 is from the cable company, not SA. The version of SARA I have is 1.85.14.2. I have had this version since I installed my SA 8300 about two months ago.
My question is, who has the latest version of this software and what kind of changes can I expect to see? That is assuming my cable company will eventually update.
hookbill is offline
post #564 of 1154 Old 01-12-2005, 09:24 AM
davehancock's Avatar
Quoted: 111 Post(s)
Liked: 60
We've got 1.85.17.3 in Rochester, NY and I have seen reports of 1.86.11.1 in CT & NJ and 1.87.4.4 in Houston (Time Warner). As I personally did not have an earlier version (only recently switched from a 8000HD) I can't comment on differences between what you have and what I have.
I believe that the 1.87 versions support Multi-Room functionality.
All current versions have a problem effortlessly viewing a program currently being recorded. We all anxiously await a fix for this.
Dave Hancock
davehancock is offline
post #565 of 1154 Old 01-12-2005, 09:44 AM
hookbill's Avatar
Yes, it was being discussed in the 8300/SARA/Cox thread. They had some interesting alternatives to solving this problem. If your interested, look here: http://www.avsforum.com/avs-vb/showt...54#post4973254
hookbill is offline
post #566 of 1154 Old 01-12-2005, 02:42 PM
I was just told my my Local Adelphia programmer that the boxes would get some new coding within the next 2 weeks that would fix the lack of "Audio: Digital Out" in the general settings and would fix numerous other issues. He didn't go into detail what those issues were but I'm hoping it may fix the kick-to-live bug.
post #567 of 1154 Old 01-12-2005, 03:03 PM
hookbill's Avatar
I'm just not too sure that this is really a bug. I think it's the way the box is designed. I could be wrong, and I hope I am but are we just assuming this is a bug?
hookbill is offline
post #568 of 1154 Old 01-12-2005, 03:33 PM
Are you talking about the lack of digital out option or the kick to live? I don't know if I technically should have called it a bug, but it's obvisouly something that 99.9999% of people would rather have fixed.
post #569 of 1154 Old 01-12-2005, 04:22 PM
hookbill's Avatar
I'm talking about the kick to live. Or even the playback not starting from the start during a recording.
hookbill is offline
post #570 of 1154 Old 01-12-2005, 04:24 PM
DoubleDAZ's Avatar
Quoted: 339 Post(s)
Liked: 397
IMHO, it's the old VCR mentality where you record something and watch it later. I'm really surprised this issue didn't come up in beta testing, but then we ll seem to be the beta testers for S-A these days.
Cheers, Dave
Reply HDTV Recorders
