MPEG2Repair: New Tool for Error Detection (also improves 169time compatibility) - Page 15 - AVS Forum | Home Theater Discussions And Reviews
post #421 of 426 Old 01-22-2012, 08:56 AM
mtallent's Avatar
mtallent is offline
post #422 of 426 Old 01-22-2012, 11:33 PM
hkazemi's Avatar
In May 2011 someone in the VideoHelp forum asked if the program was infected:
http://forum.videohelp.com/threads/3...ed-with-Trojan
Some small, not well known, antivirus programs detected it. This is almost certainly because Mark used PESpin to pack his program. Some malware does the same thing, so some antivirus software notices the PESpin packer and thinks it has found malware. In reality, the antivirus software has only found a false positive.
The current copy on mwilczyn's website has the following MD5 hashes:
mpeg2repair.zip 063ab184b86dc6919dbcf69482ff9f07
mpeg2repair.exe b57f9e302cf50195ab2917840366dda9
Those of us with a copy of the 2/15/2007 version of mpeg2repair that we downloaded years ago could post the MD5 values for the ZIP and EXE files for comparison purposes.
Easy ways to get the MD5 hash values include either of the following tools:
1.) md5sums (command line): http://www.pc-tools.net/win32/md5sums/
2.) HashTab (Windows GUI and Mac GUI): http://www.implbits.com/HashTab.aspx
hkazemi is offline
post #423 of 426 Old 01-22-2012, 11:40 PM
hkazemi's Avatar
More notes:
A few comments on mpeg2repair were on videohelp.com before they removed the page. Here is an archived copy:
http://web.archive.org/web/200705271...ls/MPEG2Repair
Some mpeg2repair wrappers/command line tools/scripts are available via these links:
1.) http://www.boling.us/ebs/apps/mpeg2repair/
Multiple, broken out below in 2-4, found on http://forum.doom9.org/archive/index.php/t-119777.html
2a.) RP said:
Alternative mpeg2repair automation script (AutoIt) that is for logging only:
http://pastebin.com/f4007dcb6
Download the .au3 file here:
http://pastebin.com/pastebin.php?dl=f4007dcb6
This should be run as a command-line. Only one argument needed, the input file. mpeg2repair will automatically add a .txt to the filename.
A lot of the code I wrote dealt with possible error messages or sudden closing of the window. I also made sure you can run more than one instance of this script.
You should also be sure to get the latest version of AutoIt here: http://www.autoitscript.com/autoit3/index.shtml
I suggest using the AutoIt compiler to convert the .au3 file to an executable - but make sure you have the CONSOLE option set!
I hope this works for you - let me know if you find problems!
2b.) buzzqw mirror of above: http://www.64k.it/andres/data/m/mpeg2auto.zip
3a.) RP said:
New script, which only tries to run mpeg2repair.exe, and not use an absolute path:
http://pastebin.com/f3aa5b831
3b.) buzzqw mirror of above: mirror http://www.64k.it/andres/data/m/mpeg2auto_V2.zip
4.) SANGER_A2 said:
Hi guys
I hope I'm not treading on anyone's toes here, but I edited the au3 files and make exes from them to better fit my purposes.
I wanted the command-line version to take in TWO filenames (the input and output file) and create a repaired TS file. I also didn't care about the logging, so instead of ticking that box, it ticks the repair box. I've tested it all and it works fine.
I also have another version (which I use instead) that runs MPEG2Repair in LOW priority instead of normal. It runs on my PVR box that doesn't have a lot of resources and I don't want the encoding process to stop it recording from TV! It runs brilliantly from my postprocessing.bat in NextPVR.
You can download my two versions here (http://sangera2.com/main/misc/mpeg2auto.html) (the EXE and AutoIt files). I've also mirrored the original two versions on my site too.
hkazemi is offline
post #424 of 426 Old 12-30-2012, 07:10 PM
DigitalfreakNYC's Avatar
Quoted: 52 Post(s)
Ad-aware constantly kills this program for me. Any chance of a normal version? frown.gif
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #425 of 426 Old 12-31-2012, 10:24 AM
GCAVS's Avatar
Quoted: 71 Post(s)
Liked: 26
There is nothing not normal about the program.
You should post about getting a corrected version of Ad-aware.
GCAVS is offline
post #426 of 426 Old 12-31-2012, 05:32 PM
TNO821's Avatar
Quoted: 18 Post(s)
A number of anti-malware tools do this with mpeg2repair because it uses a special executable "packer" to further obfuscate its code and reduce the size of the executable. Many pieces of malware do the same, which is why some tools flag all such executables as malware.
There is no other release of mpeg2repair that does not use the executable packing and the tool is now abandonware. You're best bet is to go into AdAware's options and whitelist mpeg2repair and also contact the company and tell them that mpeg2repair is not malware, and provide them it via e-mail so that they can analyse it.
-TNO821
TNO821 is offline
Reply HDTV Recorders
