The Official R5000-HD Technical Status Discussion - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #2791 of 2802 Old 11-18-2016, 03:17 PM
pendragonsound's Avatar
I can also confirm that C1382 is a very common failure source in the Dish ViP 211 receivers. Between my three units and a couple a friend owns, I've replaced something like 8 of these caps over a 10 year period.
But you may encounter other capacitor failures, some of which cause complete loss of functionality, while others may reveal minimal, if any symptoms. Not all will manifest themselves as 'bulging'. During one nasty case, I desoldered nearly all of the electrolytic capacitors in one receiver and found more than half of these to have failed. As many of these were probably serving only as bypass caps, only a few were directly causing problems.
I keep on hand a good collection of the following values for ViP 211 receivers:
2200 µF 10V (as previously noted)
10 µF 16V
10 µF 50V
100 µF 16V
Solfan likes this.
pendragonsound is offline
post #2792 of 2802 Old 11-25-2016, 09:21 AM
guho's Avatar
I bought an HDD200 (=outboard HD decoder for certain SD cable/sat receivers) with R5000HD mod installed recently from someone in order to secure a spare R5000HD mod. While the USB R5000HD board in this HDD200 looks the same as the ones in my dct2000 cable boxes, the secondary serial board found in my dct2000 cable marked s2p 1.0 is missing in the HDD200! How is it that this board is unnecessary in the HDD200? The main USB R5000HD boards have the exact same date and revision number so I do not think it is a case of consolidation of functionality into the USB board.
guho is offline
post #2793 of 2802 Old 11-25-2016, 09:46 AM
CraziFuzzy's Avatar
Different STB's exposed the signal in different ways, so they required different electronics to grab it. In the case of the ViP, I believe the daughterboard essentially converts the serial signal that was on the board to a parallel signal that the R-5000HD takes in, then transmits to the computer. The DCT boxes instead exposed it as parallel already, so only the R5000HD board was required. If I remember right, the ViP mods were more expensive than the cable box ones.
CraziFuzzy is offline
post #2794 of 2802 Old 11-25-2016, 01:04 PM
ctdish's Avatar
Quoted: 71 Post(s)
Liked: 35
I have had a series of R5000 mods. The first two were in a Dish 6000 and an HDD200. Neither had the second board. I later got the mod in a Dish 211 and a Starchoice receiver. Both have the second board. I guess the second board was found to be necessary for the newer receivers.
John
ctdish is offline
post #2795 of 2802 Old 01-09-2017, 11:11 AM
boiler11's Avatar
Two R5000-HD modded Dish VIP-211s for sale in near future.
Hi,
I have two Dish VIP-211s with the R5000-HD modification. I just canceled my Dish account.
I have to wait 30 days to find out what my un-returned equipment fee will be. Dish confirmed if I don't return the boxes and pay the un-returned equipment fee that they will become "purchased" boxes and can then be re-activated on another account.
Is anyone interested in purchasing them?
Sean
boiler11 is offline
post #2796 of 2802 Old 01-23-2017, 02:56 PM
PM sent.
post #2797 of 2802 Old 02-14-2017, 09:32 AM
Solfan's Avatar
Quoted: 14 Post(s)
Liked: 32
Lightbulb
Originally Posted by swSteve View Post
Just a heads up
With a friend's help I was able to repair
two dead Dish VIP211 R5000HD units
Both units would repeatedly
crash and restart.
It got to the point where they were unable to boot.
In both cases, Capacitor C1382 was bulging.
( 10volt 2200uF )
That caused the 2.6 Volt power regulator circuit
to fall below operational limits to around 2.5 Volts
We installed a quality 25Volt 2200uF replacement
made by NICHICON JAPAN from DigiKey and
the voltage returned to 2.6
Both receivers are now running fine.
Steve
10 µF 16V
10 µF 50V
100 µF 16V
A treasure trove of valuable info here, thanks guys!
Solfan is offline
post #2798 of 2802 Old 03-01-2017, 10:53 AM
searcher2's Avatar
I just had my 211 die on me. Where can I get a schematic of it so I can find which caps you're talking about?
Also, does anybody know of anyone that fixes them? I have 2 that's dead.
searcher2 is online now
post #2799 of 2802 Old 03-02-2017, 08:44 AM
ctdish's Avatar
Quoted: 71 Post(s)
Liked: 35
I doubt you will find a schematic. The Caps are all labeled on the top of the board. You might need a bright light and maybe a magnifying glass.
The board is a good heat sink which makes soldering a little difficult. Not a job for a first time soldering project using a cheap soldering iron.
John
ctdish is offline
post #2800 of 2802 Old 03-02-2017, 09:56 AM
searcher2's Avatar
Thanks John,
I'm mediocre at soldering. I'll try and fix it myself but I'd prefer to pay an expert to do it.
If anybody want to sell your VIP211 please let me know.
Rick
post #2801 of 2802 Old 03-07-2017, 08:07 PM
btrcp2000's Avatar
I have at least one maybe two i would consider parting with. Both are Vip211, were working fine when i got a better deal from the cable co and cancelled dish but have been on the shelf for a few years now. Both are owned free and clear. Not sure of their value, but i would entertain offers
btrcp2000 is online now
post #2802 of 2802 Old Today, 05:44 PM
searcher2's Avatar
Great btrcp2000,
Please contact me at searcher <at> ameritech <dot> net
Reply HDTV Recorders
