AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   HDTV Recorders (http://www.avsforum.com/forum/42-hdtv-recorders/)
-   -   JVC Dishnetwork D-VHS Discontinued? (http://www.avsforum.com/forum/42-hdtv-recorders/48796-jvc-dishnetwork-d-vhs-discontinued.html)
talkdj 05-28-2000 08:55 PM
Just wondering..
I was up at the Dishnetwork site a couple of day's ago and noticed that they are not offering the JVC D-VHS anymore. Does that mean that it's discontinued??
Gees, I just got the thing a couple of months ago!
-Wynn
talkdj 05-30-2000 12:33 PM
Well to answer your question first. Yes, I have noticed a couple of times on movies that there is the intermitent blackouts that you experienced. I just chalked it up to some irregularities in the tape (which i thought was odd,being it DVHS and such). I actually don't use the DVHS tapes that much since I usually record stuff off my local stations and since it's considered analog off the DMS-100 I can't record digitaly anyway's. I have used it to record stuff off of the movie channels etc and it works great. I liked the idea that I could record the movies on the DVHS tape and keep the superior quality and keep the ac-3 dolby soundtrack (if it was sent that way).
I hope they continue to make tapes for it. Or should I just sell it on ebay and cut my losses??
Hope that helps
Wynn
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
