PVHD1000: 5nF - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-14-2000, 01:19 AM - Thread Starter
Don Landis's Avatar
Quoted: 1217 Post(s)
Liked: 321
Tonight I discovered I had a "5nF" displayed from an attempt to record a program. The recording was blank. It appeared that my DST50 was failing to send a digital signal to the recorder after working fine for months. Without switching off and on I put the recorder in playback mode from the DST50 on screen and then it worked. Then recorded a whole movie just fine from the local control.
Has anyone seen this error message 5nF? I now assume it indicates no digital signal in recorder's 1394 input but I have just never seen it before.
Don Landis
NEW! Home Theater Pics at:www.scubatech.com updated 5/11/00
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K
Don Landis is offline
post #2 of 10 Old 06-14-2000, 10:21 PM
marv's Avatar
Don- are you sure that's not "5C" coming up on the screen? http://www.avsforum.com/ubb/wink.gif
Best, Marv
marv is offline
post #3 of 10 Old 06-15-2000, 12:38 AM - Thread Starter
Don Landis's Avatar
Liked: 321
It was 5nF, not 5C. At first I thought it might have something to do with that but I was able to reset the tuner and correct the problem.
Don Landis
post #4 of 10 Old 06-15-2000, 12:47 AM
tmitchmd's Avatar
"Paranoia strikes deep; into your dreams it will creep..."
"Dammit Jim, I'm a doctor not an engineer."
tmitchmd is offline
post #5 of 10 Old 06-15-2000, 06:57 PM
Cheezmo's Avatar
Quoted: 171 Post(s)
Liked: 116
Doesn't anyone use their manuals any more?
Page 37.
"INPUT SIGNAL NOT FOUND" is displayed on the screen and/or "SnF" is displayed in the Multi Function Display during digital recording...
CORRECTION
* Make sure the IEEE 1394 cable is properly connected.
* Turn the Set Top Box* power off and then on again
*When using the Set Top Box TU-DST50 only.
Anyway, that is what is in the manual about it.
Steve Martin
The Widescreen Movie Center
Steve Martin
former ISF Calibrator
If you can see my pixels, you are sitting too close.
Sony XBR75X940D, Sony XBR55X930D, Samsung UBD-K8500, Oppo BDP-103, Oppo BDP-93,
Cheezmo is offline
post #6 of 10 Old 06-15-2000, 08:55 PM - Thread Starter
Don Landis's Avatar
Liked: 321
Yes, Steve, I did look specifically on that page, infact scanned the whole manual looking for it, but didn't see it in my haste! I was not looking for "INPUT SiGNAL NOT FOUND but you're right, it's there in the fine print. S (not 5 which is what it looked like on my panel) But had I taken more time I would have figured it out. As I said resetting the STB did the trick!
Don Landis
post #7 of 10 Old 06-16-2000, 07:01 AM
Cheezmo's Avatar
Quoted: 171 Post(s)
Liked: 116
I didn't mean to sound harsh. I actually intended a smiley but forgot it. I saw that same message (SnF) once several months ago (and freaked accordingly) but did find the thing in the manual which is the reason I remembered it. Nice to know the solution you came up with is the recommended one http://www.avsforum.com/ubb/smile.gif
Steve Martin
Steve Martin
Cheezmo is offline
post #8 of 10 Old 06-16-2000, 07:57 AM - Thread Starter
Don Landis's Avatar
Liked: 321
Steve, I deserved it! What goes around comes around and I'm always accusing others of not reading the manual. I just overlooked it that evening and I didn't think you were harsh at all. Heck, with a name like Steve Martin, well, the name itself brings smiles!
Don Landis
post #9 of 10 Old 06-16-2000, 09:23 AM
Cheezmo's Avatar
Quoted: 171 Post(s)
Liked: 116
Well then...
EXCUUUUUUUUUSE MEEEEEEEEEEEEEE!!
Steve Martin
Steve Martin
Cheezmo is offline
post #10 of 10 Old 06-17-2000, 10:18 PM
Richard Adams's Avatar
I've seen the "5nF" display when attempting to dub from one unit to another. This makes dubbing very tedious since it is a blind operation. I may need to reconnect the STB and reposition the tapes when this happens, if I happen to be dubbing within the tape rather than at the beginning.
I hope those friends of mine get their cuts editor for HD mpeg working.
"With Liberty, HDTV and Justice for all."
Richard Adams
Richard Adams is offline
Closed Thread HDTV Recorders
