CHECK IT OUT,, is this A NEW d-VHS RECORDER?? - AVS | Home Theater Discussions And Reviews
post #1 of 19 Old 02-16-2001, 08:40 AM - Thread Starter
brettb's Avatar
what is this thing?? it looks cool anyway? sounds like in import?? will it work??http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1215249775
brettb is offline
post #2 of 19 Old 02-16-2001, 08:48 AM
greenwing's Avatar
The seller has zero previouis history on ebay...Buyer beware...
kenmullins
newnan, ga usa
GreenWing
newnan, ga USA
greenwing is offline
post #3 of 19 Old 02-16-2001, 11:13 AM
barry kelman's Avatar
This looks very much like the unit that Li On tested several months ago. As I recall, he was unable to get it to work with the TU-DST51, or any other US consumer product.
Note that JVC stands for 'Japan Victor Corporation', so this is not a sister company of JVC, but JVC themselves - they just use the JVC brand here.
Li On, care to comment?
Thanx,
Barry
barry kelman is offline
post #4 of 19 Old 02-16-2001, 11:18 AM
TraderGordo's Avatar
Not sure of the history of JVC, but I thought they changed their name from Victor to JVC like 10 or more years ago?
Anyway, this "LOOKS" like the JVC DVHS machine we have been hearing about. The description is also consistent with Gary Merson's description of it in his last newsletter. It has i.Link in/out, which is actually very good news (no DVI). Someone correct me if I'm wrong, but i.Link is the same thing as "Firewire", which is the same thing as a 1394 interface right? If so, this thing should work with the 169Time recorder, which would be phat.
I hope these puppies will be selling down in the $1000 or lower range. Definitely wouldn't buy from some new ebay seller in Japan, but it looks good. And to be honest with you, I think most people should and will wait for a PC based recording solution which offers much more flexibility and cost savings in my opinion. You could definitely buy the PC based solution for less than $1000 (I'm talking a complete dedicated home theater bare bones separate machine from your regular pc) which will record about 10 hours of high definition. Add a tape backup, and you can archive anything you want. I believe you will be able to buy this solution very soon (within next few months).
The flip side is -- what will everyone do when JVC releases a 100 high def movies on DVHS and THEIR system is the only thing that plays them?
TraderGordo is offline
post #5 of 19 Old 02-16-2001, 01:26 PM
tmitchmd's Avatar
This is the JVC 30000 which was shown modified with the DVI/HDCP interface at the recent CES. If compatible with ATSC (a big IF) then it will be a fabulous unit. JVC has expressed plans to import them this summer, but I believe this unlikely in the current environment.
"Dammit Jim, I'm a doctor not an engineer."
tmitchmd is offline
post #6 of 19 Old 02-16-2001, 01:44 PM
rjcrum's Avatar
Regarding i.Link....as far as I know, that is Sony's trademarked name for their implelemtation of the IEEE 1394 interface. I don't know all the details, but I belive their implementation varies somewhat from the standard regarding the availability of DC power through the interface. I'm surprise to see JVC use that....but on another look, that may be the SELLER saying 'i.Link' as a generic term for the 1394 interface.
Buyer beware.
rjcrum is offline
post #7 of 19 Old 02-16-2001, 03:33 PM
ROBERT HUNZEKER's Avatar
Be very careful with the ebay auctions for the japanese decks, they are ripping people off bigtime. The Sony DV/VHS deck on ebay right retails for $1400 and sells in Japan for around $8-900. THe DV/SVHS Sony retails for $1800 and goes for $1100. The are selling them on ebay for well over $2000 and making like they are giving you such a deal.
Bob H.
ROBERT HUNZEKER is offline
post #8 of 19 Old 02-16-2001, 05:29 PM
dkeller_NC's Avatar
Hopefully, absolutely nothing! http://www.avsforum.com/ubb/smile.gif
BOYCOTT DVI/HDCP & JVC!
dkeller_NC is offline
post #9 of 19 Old 02-16-2001, 10:07 PM - Thread Starter
brettb's Avatar
I also see he is from Tokyo Japan, so beware of what you buy????
Its seems to be a sister company of JVC??
regards,
brett
brettb is offline
post #10 of 19 Old 02-17-2001, 02:23 AM
juniormaj's Avatar
JVC (Japan Victor Corporation) is still known and sold as "Victor" in Japan.
"i.Link" is Sony's brand name for IEEE1394.
"FireWire" is Apple's brand name for IEEE1394.
They are the same protocol, the only difference being who gets royalties for the name.
-Jr.
juniormaj is offline
post #11 of 19 Old 02-17-2001, 06:47 AM
chap's Avatar
In case you were wondering the full model # of this device it is the HM-DH30000. I was looking for an opportunity to buy this box, but I initially thought it had Component inputs on it, which the japanese version does not. The component outputs it has from my understanding aren't your typical RGB connections. Its actually a special D shaped connector which means unless you get some type of cable convertor that won't help you much either. After all of the looking and waiting for a DIFFERENT DVHS option to materialize, I think I might just get the Panasonic model, and wait for 169 to come out with a Dish 6000 model.
STOP DVI/HDCP!!!!!
chap is offline
post #12 of 19 Old 02-17-2001, 09:45 AM
bbq@KL's Avatar
HM-DH30000 costs about 160,000JPY=1381USD. (take a look at kakaku.com )
Note that it has one D1/2/3/4 termainal.
I guess that D terminal is only useful in Asia, huh? http://www.avsforum.com/ubb/smile.gif
BTW, what is the difference between SDI and D1 terminal in Japan?
bbq in Kowloon, waiting for Radeon custom T&R (desperately)
bbq@KL is offline
post #13 of 19 Old 02-17-2001, 12:28 PM
AVS Club Gold
dahester's Avatar
Although its ability to record from the Panasonic TU-DST50/51 is suspect, I believe this deck will work properly with any tapes recorded on the PV-HD1000. The specs do confirm the SPDIF output will handle Dolby Digital in addition to AAC (which is the Japanese DTV audio spec). In general terms, if a device can handle transport streams carrying MPEG-2 video and AC-3 audio, it will work with our ATSC DTV system.
What I'd like to know is if 169Time can reverse engineer the 1394 protocol for this deck. Also, we need to figure out what that funny D4/3/2/1 connector has on it, so we can get the video into standard YPrPb or RGB-HV form.
-D
Displays: Sony VPL-HW40ES | 110" SI Motorized Slate screen | Pioneer PRO-150FD
Sources: Sony BDP-S5000ES | Dune HD Smart D1 | Roku HD | LG LST-3410A HD-DVR
Speakers: Nearfield Pipedreams 18 (L,R,Sub1,Sub2), Pipedreams 15 (C)
| Magnepan MC-1 (WL, WR, SL, SR, SBL, SBR)
Audio: Denon AVR-4311CI | Bryston 6B-SST | Bryston 14B-SST
Control: Control4 home automation
dahester is offline
post #14 of 19 Old 02-17-2001, 02:28 PM
tmitchmd's Avatar
How does one access English on the Kakaku.com website?
tmitchmd is offline
post #15 of 19 Old 02-26-2001, 09:27 PM
Li On's Avatar
<font face="Verdana, Arial" size="2">Originally posted by barry kelman:
Thanx,
Barry
</font>
Hi Barry,
Didn't know my name was mentioned til I did a search! Anyway, it's the just released Victor HM-DH30000 DVHS deck.
I've now used the DH30000 for 4 days. And it's great!
The DH30000 is a most advance SVHS/VHS deck. But we're not interested in
that area! Let's talk about it's DVHS function.
The DH30000 can playback both US/Korea ATSC HD tape and Japanese HD tape
on it's own with it's internal picture/sound decoding. The video output is
in component YPrPb format at:
1. native, pass all formats including 480p/1080i/720p
2. 720p convert to 1080i, all others native
3. convert all formats to 480i (useless!)
The output connection at the back panel is in Japanese D-sub format but a
stock D-sub to 3 RCAs cable which I'm using now will take care the issue.
There's a optical digital audio output at the back panel. The sound format
can be set at 'native' or '2ch PCM'. At 'native' it'll pass the ATSC DD or
Japanese AAC format to external decoder. At '2ch PCM', it'll convert both
ATSC DD and Japanese AAC to PCM to external decoder. I haven't tried it's
analog audio yet.
Jaehong Lee (a avsforum member) confirmed the DH30000 works with the US
Panasonic STB TU-DST50/51 for HD recording. The DH30000 can playback all recorded HD tape but don't have a HDTV tuner buildin. You need a external STB with 1394 interface to use it's HD recording function.
Anyone want to get it can email me. Thanks in advance.
regards,
Li On
Li On is offline
post #16 of 19 Old 02-27-2001, 08:02 AM
helfy's Avatar
Where do I get one?? How much$$$$$
Michigan's Best Home Remodeler!
helfy is offline
post #17 of 19 Old 02-27-2001, 10:58 PM
John Tuohy's Avatar
"BTW, what is the difference between SDI and D1 terminal in Japan?"
I believe SDI is also called D-1.
John Tuohy
All I ever want is everything
John Tuohy is offline
post #18 of 19 Old 02-28-2001, 01:06 PM
bbq@KL's Avatar
"I believe SDI is also called D-1"
It is really interesting. http://www.avsforum.com/ubb/smile.gif
Toshiba SD-1200 is a DVD player with D1 output
http://www3.toshiba.co.jp/dvd/j/player/p_fr11fc.htm
http://www3.toshiba.co.jp/dvd/j/play...h/f_d1port.gif
The price of SD-1200 is (only) 19,500 yen.
http://kakaku.com/prdsearch/detail.a...duct=SD%2D1200 (about 165 dollars)
Both SDI and D1 support only 480i.
Besides, SDI is also known as SMPTE 259M.
http://www.smpte.org/stds/stnumber.html
Maybe there is a difference between D1 and SDI?
Otherwise, SD-1200 will not be that affordable. http://www.avsforum.com/ubb/smile.gif
bbq@KL is offline
post #19 of 19 Old 02-28-2001, 10:58 PM
h2ofun's Avatar
Is this has an SDI plug, does this mean you could drive with a modified DVD with an SDI output, put into this unit and project via STB?
dave
h2ofun is offline
Closed Thread HDTV Recorders
