Drop out free recivers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-10-2001, 08:27 AM - Thread Starter
Joby in FBG's Avatar
I have the TUDS/50 and VCR and Technics decoder. Im thinking about getting one of the new 7.1 recivers like the HK 8000 or the Dennon 3801. Since almost all of my movie watching uses the HDTV VCR, to take advantage of the surround back channels I will have to use the reciver as the 5.1 decoder. Does anyone know if Harman Kardan or Dennon recivers suffer from the drop out problem?
Joby in Fredericksburg
Joby in FBG is offline
post #2 of 7 Old 04-10-2001, 03:52 PM
Hal
Hal's Avatar
Joby, I have the DST-50 and HD1000; I tried my Denon 4800 as a sound
decoder, and got frequent and annoying dropouts, which went away when
I switched to a Technics 500 decoder. So I would say that Denon is not
a good bet.
Hal
Hal is offline
post #3 of 7 Old 04-10-2001, 05:11 PM
dahester's Avatar
Hi Joby. The high-end Denon receivers use the Analog Devices DSPs, which will very likely have audio dropout problems. Any receiver that uses Crystal/Cirrus DSPs will not have this problem because of the way these audio processors handle errors in AC-3 data (the Technics SH-AC500D uses a Crystal decoder).
As far as 7.1 receivers go, Harmon Kardon, Onkyo, and the latest Yamaha units (DSP-AXX) will be immune from the dropout problem. Personally I would go with the Onkyo TX-DS989 since it is software-upgradable via its RS-232 serial port. Hope this helps.
-Dylan
[This message has been edited by dahester (edited 04-10-2001).]
Displays: Sony VPL-HW40ES | 110" SI Motorized Slate screen | Pioneer PRO-150FD
Sources: Sony BDP-S5000ES | Dune HD Smart D1 | Roku HD | LG LST-3410A HD-DVR
Speakers: Nearfield Pipedreams 18 (L,R,Sub1,Sub2), Pipedreams 15 (C)
| Magnepan MC-1 (WL, WR, SL, SR, SBL, SBR)
Audio: Denon AVR-4311CI | Bryston 6B-SST | Bryston 14B-SST
Control: Control4 home automation
dahester is offline
post #4 of 7 Old 04-10-2001, 05:40 PM
Ken H's Avatar
Some Marantz should be Ok, the SR-18 and simular models work fine with the TU-DST51.
"better living thru modern expensive electronics"
tm
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #5 of 7 Old 04-11-2001, 06:31 AM
Mike2's Avatar
I'm in the same situation as Joby. Does anyone know if the Lexicon pre/pros have the dropout problem with the Panasonic HD1000?
Mike
Mike2 is offline
post #6 of 7 Old 04-11-2001, 07:37 AM
achase's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mike2:
Mike
</font>
My DC-1 seems to work just fine.
achase is offline
post #7 of 7 Old 04-11-2001, 12:16 PM
Mike2's Avatar
Thanks achase.
Mike2 is offline
Closed Thread HDTV Recorders
