Can you use a HTPC as HD recorder? - AVS Forum | Home Theater Discussions And Reviews
Old 04-11-2001, 07:06 PM - Thread Starter
Tractor_Boy's Avatar
Hi
Can you use a PC with appropriate boards and hard drives as a HD video recorder ?
Hard drives are getting cheaper per GB all the time and a fast PC would give you plenty of ability to program and record HD signals.
Is there such a beast S/W and H/W ?
James
Tractor Boy
Sydney
Australia
Tractor Boy
Sydney
Australia
Bits every where
Tractor_Boy is offline
Old 04-11-2001, 08:39 PM
kelliot's Avatar
Check out the HTPC forum. I don't know what system they use down under, but the HTPC forum has a large number of posts with regard to timeshifting using various HD tuner cards.
Ken Elliott
[This message has been edited by kelliot (edited 04-11-2001).]
Ken Elliott
kelliot is offline
Old 04-11-2001, 11:47 PM
Crusher's Avatar
James,
If you keep 28.2Mb/s (HS mode), you need around 25GB for every two hours. Would that be a bit expansive?
Crusher
Crusher is offline
Old 04-12-2001, 05:43 AM
frankx99's Avatar
The accessDTV card can record HDTV at 9GB per hour.
frankx99 is offline
Old 04-12-2001, 04:36 PM
Glimmie's Avatar
Quoted: 620 Post(s)
Liked: 508
The HiPix is also a great option. It had a few initial problems but I am running version 2.2 and it's now very stable. Just watched all of "Rain Man" last night without a single studder or audio hit.
The entire folder size was 18gB. But I over-recorded too. The approx HiPix rates are 7gB per hour.
Glimmie is offline
Old 04-12-2001, 05:38 PM
Cliff Watson's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Glimmie:
</font>
How can the HiPix be a great option when you can't buy one? I have 300 backordered with no word on when the order will be filled.
Best Regards, Cliff
Digital Connection, LLC
cwatson53@home.com
Cliff Watson is offline
taboola here
