Viewing while dubbing between two PV-HD1000's? - AVS Forum | Home Theater Discussions And Reviews
Old 04-18-2001, 04:38 PM - Thread Starter
cymro's Avatar
I have just been dubbing between two PV-HD1000's. This seems to work well enough.
However, to do this, I have to disconnect the firewire cable from the DST50 STB, and connect the firewire cable directly between the two Hidef PV-HD1000 VCR's. As a result, I can't view the material while dubbing proceeds - very awkward for editing!
Does anybody know of a solution to this? Would a firewire hub/router work? I noticed that there seems to be a lot of firewire stuff available for computers, but most appear to be for six conductor firewire cable, whereas the PV-HD1000's seem to use four conductor cable.
Is there a simple passive switch box that can connect either the STB or another PV-HD1000 to the main PV-HD1000?
Thanx
cymro is offline
Old 04-18-2001, 05:10 PM
Glimmie's Avatar
Quoted: 639 Post(s)
Liked: 516
I have tried two different firewire hubs on my Panny combo and neither will work even if it's just the PVHD1000 and DST50/51. I don't know of any way to monitor and since 1394 is bidirectional, you couldn't just "listen in"
But hey, it's digital. What could go wrong? Famous last words!
Glimmie is offline
Old 04-18-2001, 05:11 PM
Glimmie's Avatar
Quoted: 639 Post(s)
Liked: 516
<font face="Verdana, Arial" size="2">Originally posted by cymro:
Thanx
</font>
Yes there is, www.markertek.com
Glimmie is offline
Old 04-19-2001, 01:07 PM - Thread Starter
cymro's Avatar
Glimmie,
Thanx for your input
cymro is offline
