PV-HD1000 turned OFF suddenly? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-30-2001, 12:04 PM - Thread Starter
jlin's Avatar
Yesterday I was recording from Showtime last night. While watching the movie live, my PV-HD1000 suddenly turned itself off. The remote was on the desk far away from me so there was no way I could have accidentally touch it. Note the VCR was turned off completely.. I saw on the screen "VCR off"
This is the second time it has happened. The last time was about 3 weeks ago.. also in the middle of a Showtime movie.
Anyone with similar problem?
jlin is offline
post #2 of 6 Old 04-30-2001, 12:21 PM
Brajesh's Avatar
Quoted: 305 Post(s)
Liked: 130
Is it possible you've set the timer in your DST50/51 & forgotten about it? The timer must be turned to the 'Off' state.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #3 of 6 Old 04-30-2001, 12:45 PM - Thread Starter
jlin's Avatar
No.. it wasn't a timer event. I was there when I pushed the record button.
jlin is offline
post #4 of 6 Old 04-30-2001, 04:26 PM
gridleak's Avatar
Quoted: 12 Post(s)
My 51/HD1000 combo seems to act differently from my 50/HD1000 combo in regards to recorder control. The 51 allows independent control with the recorder's remote, where the 50 doesn't. For example, sometimes I can't turn the recorder off because the 50 won't allow it. I acts like it's in the middle of a recording session.
I'm suggesting that even though you started the recording manually, one of the STB's timers might have issued an "off" command.
- gridleak... biased toward HD
-Roger
gridleak is offline
post #5 of 6 Old 05-01-2001, 04:08 PM
jrichards's Avatar
Did you hit the record button more then once? I have done this before by accident. If you press the record button more then once it will automatically stop in 30 min. increments. 2 presses 1 hour, 3 presses 1.5 hours etc....
Jeff
jrichards is offline
post #6 of 6 Old 05-01-2001, 04:38 PM - Thread Starter
jlin's Avatar
Hm... that could be it!
I can check my recording. If it only recorded 30 minutes, then I must have triggered the 'quick timer' record by accident.
jlin is offline
Closed Thread HDTV Recorders
