HIPIX owners will this work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-04-2001, 12:04 PM - Thread Starter
Sil
Sil's Avatar
Just a thought,has anyone with a hipix card
tried sending a RGB signal into the VGA in
on the card?I'm thinking this might work for
a HDD200 HD decoder.
Sil
Sil is offline
post #2 of 9 Old 05-04-2001, 02:16 PM
gridleak's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Sil:
...sending a RGB signal into the VGA in
on the card?
</font>
Isn't that just a bypass input so you can switch between your normal VGA card and the HiPix?
- gridleak... biased toward HD
-Roger
gridleak is offline
post #3 of 9 Old 05-04-2001, 02:36 PM - Thread Starter
Sil
Sil's Avatar
I was just at a friends who uses it for
a completely diff. app. and saw it had
a VGA in.He doesn't have any sat. and
no OTA HD up here in Canada.I'm assuming
the VGA in can be captured then played back
as a file.
Sil
Sil is offline
post #4 of 9 Old 05-04-2001, 02:55 PM
gridleak's Avatar
What does he use the HiPix card for?
-Roger
gridleak is offline
post #5 of 9 Old 05-04-2001, 04:50 PM
KeithIrwin's Avatar
I don't own a card, and will gladly yeild to the knowledge of anyone who does, but it is my understanding that the VGA in is simply a pass-thru for the output of one's existing graphics card. So that one can hook the graphics card up to the Hi-Pix and the Hi-Pix up to the monitor. Compressing an uncompressed HD signal, such as a VGA one would require fairly huge computational resources, I'm fairly sure that the necessary hardware would raise the price significantly at this point in time, were they to include it in the card.
Keith
KeithIrwin is offline
post #6 of 9 Old 05-04-2001, 05:28 PM
boat-anchor's Avatar
The VGA in is just for pass through so you can view the menus and
such using your regular VGA card until you select "HDTV" playback
at which time it shuts off the VGA passthrough and the HiPix card
takes over driving the VGA monitor.
You can buy many types of standalone "scan converters" which will take
VGA input and then output NTSC which could be recorded. Unfortunately
you are stuck down-converting to NTSC (approx 640x480 resolution)
boat-anchor is offline
post #7 of 9 Old 05-07-2001, 03:55 PM
Jeff T's Avatar
It should take about 8.6G per hour for HD. This would yield about 3 hours on a 30G unit.
- Jeff
- Jeff
Jeff T is offline
post #8 of 9 Old 05-08-2001, 03:02 AM
Yes, just over 3 hours on 30 gigs. That is assuming you store
the "unmolested" 8VSB/ATSC data stream as it is broadcast.
I think we may see an HDTV PVR direct from dish network before
Tivo gets around to messing with HDTV. So far everyone is scared
that the market still isn't very big... But that will change over
time.
post #9 of 9 Old 05-08-2001, 08:04 AM
trbarry's Avatar
<font face="Verdana, Arial" size="2">It should take about 8.6G per hour for HD. This would yield about 3 hours on a 30G unit.</font>
That's a lot, and it's probably not economical yet to recompress it much more. However that could probably be improved for the average stream 10-30% just by stripping out only one program stream and maybe a bit more by stripping some filler stuff. Also, whether we like it or not, most stuff broadcast now is SDTV or upconverts that take up even less space when stripped.
- Tom
(This sentience has tree errors.)
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors?
Tom Barry - Find my video filters at www.trbarry.com
trbarry is offline
Closed Thread HDTV Recorders
