Favorite way to skip CBS commercials on PV-HD1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-06-2001, 01:50 PM - Thread Starter
jlin's Avatar
Since visible fast scanning isn't available on the PV-HD1000, what's your favorite way to skip the commercials on CBS shows?
Personally I stop the playback, fast forward for 2-3 minutes, press play again. Typically I only have to watch another 30 seconds of commercial before the actual show comes back.
Is this better than fast scanning 3 minutes without hitting stop on the VCR's long term life?
jlin is offline
post #2 of 6 Old 05-06-2001, 09:43 PM
bb1987's Avatar
Since I absolutely detest watching anything that is interrupted by commercials, what I do is go through the trouble of taping the show, then writing down the points at which each commercial starts and stops, then dubbing the movie minus commercials to a new tape and watching that tape commercial free. Of course this is a lot of work and I only do this when I like a movie enough to make it part of my library.
Bernhard
bb1987 is offline
post #3 of 6 Old 05-07-2001, 10:10 AM
Brajesh's Avatar
Quoted: 302 Post(s)
Liked: 130
I too detest commercials. I edit out the commercials while taping. CBS switches from 4:3 to 16:9 when going from commercials back to program...with it, the 'CBS eye' logo shifts...that's my cue to resume recording from a rec pause.
Surf on to ... THE BEST FILMS & HOME THEATER
[This message has been edited by Brajesh (edited 05-07-2001).]
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #4 of 6 Old 05-07-2001, 10:21 AM
rczarne's Avatar
There is a button on the remote that fast forwards 1 minute. I believe it is labeled zero/1min .
rczarne is offline
post #5 of 6 Old 05-09-2001, 02:06 PM
Cheezmo's Avatar
Quoted: 184 Post(s)
Liked: 121
I use the one minute forward scan button (3 usually does it). I can't see the front panel so stopping and fast forwarding would give me no time feedback, so I pretty much have to use the forward scan feature anyway.
Steve Martin
The Widescreen Movie Center
Steve Martin
former ISF Calibrator
If you can see my pixels, you are sitting too close.
Sony XBR75X940D, Sony XBR55X930D, Samsung UBD-K8500, Oppo BDP-103, Oppo BDP-93,
Cheezmo is offline
post #6 of 6 Old 05-09-2001, 06:42 PM
cnixon's Avatar
The forward scan mode has an OSG with time indication and it's easier to skip three minutes watching this than pressing the one minute skip scan three times. I wish I could quickly press the one minute skip scan three times and move ahead three minutes.
Charles
cnixon is offline
Closed Thread HDTV Recorders
