Need suggestion for Dallas DTV antenna problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-12-2001, 11:56 AM - Thread Starter
DSperber's Avatar
Quoted: 227 Post(s)
Liked: 186
I need a suggestion for a solution to a DTV antenna problem,
if there is a solution.
I have a Dish 5000/modulator setup, going into a Panasonic
DST50/PV-HD1000 combo. And I also have an off-air antenna
for reception of local network DTV (and HD, when broadcast)
so that I can record HBOHD from the satellite as well as
local network DTV and HDTV. I also receive the local
Dallas networks via satellite, eliminating my need for
crystal clear reception of local networks off-air. It's
only the local network DTV signals that I really care about
from my off-air antenna.
I live in North Dallas (north of Galleria, just east of the
Tollway). I've installed an outdoor antenna in the attic
of my all-wood 2-story apartment building and had it aimed
quite precisely to the SSW. That's where the map shown at www.antennaweb.org shows all of the networks to be sending
their VHF and DTV signals from, relative to where I live.
All network VHF stations come in perfectly fine, although
as stated earlier I watch local networks analog VHF via
satellite. Naturally the off-air reception isn't as good
as the satellite-provided feed, for analog VHF.
And most, but not all, of the network DTV stations are
tuned perfectly by the DST50. ABC (9), NBC (41), and
FOX (35) are received correctly so that when I select
4 (FOX), 5 (NBC) or 8(ABC) on the DST50 the partner DTV
channel is automatically tuned and displayed.
However the DTV partner for CBS (19) simply will not
tune. The DST50 shows "input signal found" in green, but
also shows "no channel available", indicating that it is
too weak I believe. Sometimes "input signal not found" is
shown, but if I wait a while it will change to "input signal
found". Nevertheless, "no channel available" is hard.
This is odd, since CBS VHF (11) comes in better than NBC VHF
and FOX VHF, with the latest re-positioning/re-aiming of my
outdoor antenna. In fact, CBS VHF (11) looks great off-air.
You'd think this would bode well for CBS DTV (19).
So what's the story with CBS DTV (19)? Obviously, there's
some problem with reflections or blockage coming from the
south up through downtown or the Galleria area or the new
buildings now constructed on the west side of the Tollway
south of me. Oddly, it seems to affect the DTV channel
more than it affects the VHF channel.
My question is, can I do anything about it? Is there
any alternative antenna which might have better luck with
specifically this one particular UHF frequency? I could
"blend" in the additional special antenna, if it would
only work.
Is there a UHF antenna solution that would pick up 19 with
much better quality than what I have now? If so, what is
that brand?
I'd really like to be able to receive CBS DTV/HD here in
Dallas as they typically broadcast 3 hours during prime time
each night. And they also broadcast basketball, golf, and
tennis(?) in HD, which makes life worth living.
Can anybody suggest a solution? Thanks in advance.
DSperber is offline
post #2 of 3 Old 05-14-2001, 07:09 AM - Thread Starter
DSperber's Avatar
Quoted: 227 Post(s)
Liked: 186
Originally posted by PDoyle:
Have you tried rotating your antenna off-axis? Sometimes this helps with the digital stations. I live in west Plano near the northern end of the tollway and I have no problems with any of the local digital feeds using an antenna in the attic and an RCA DTC100.
No, I haven't. The install was done by Goodman TV, and
they came out a second time a few days ago to try and
re-aim it for possibly better reception. We managed to get
CBS VHF to come in much better (it was exhibiting an obvious
rainbow beat frequency from ghosts/reflections, and now
it's quite clean and stable) so we though the DTV version
would also be improved. However no such luck.
By "off-axis" do you mean "non-vertical, non-horizontal"?
That idea certainly never had occurred to us... just
re-aiming it (i.e. rotating it around its vertical mast).
Somebody suggested trying an in-line amplifier, as maybe
the signal from CBS DTV might be marginal. Of course it's
coming out of the Dish HDTV Modulator, not directly off of
the antenna. The antenna feeds the Modulator, which in
turn feeds the DST50.
Your good luck with the DTC100 might suggest it's more
sensitive than the DST50. Perhaps I'll give the in-line
amplifier a try.
Did you install your attic antenna yourself? Wanna come
over and give mine a tweak???
DSperber is offline
post #3 of 3 Old 05-14-2001, 03:07 PM
Don Landis's Avatar
Quoted: 1225 Post(s)
Liked: 328
You are in the wrong forum for your question. Please delete it and repost it in the HDTV Hardware section.
Don Landis
Home Theater Pics at: www.scubatech.com Last updated 3/25/01
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K
Don Landis is online now
Closed Thread HDTV Recorders
