AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   HDTV Recorders (http://www.avsforum.com/forum/42-hdtv-recorders/)
-   -   accessDTV Windows 2000 RAID question (http://www.avsforum.com/forum/42-hdtv-recorders/48998-accessdtv-windows-2000-raid-question.html)
mkerdman 06-02-2001 02:54 PM
Has anyone configured an HTPC with accessDTV Windows 2000 using multiple HDD's in a RAID aray such that all 2-4 HDD's are seen by accesDTV as the C Drive.
If so, what happens when a recording would otherwise span the physical space from one drive to another? Does accessDTV only place it in a partition with enough gigs- or does it fail to fully record if drive "1" lacks enough capacity?
Please advise.
Murray
Joe Q 06-02-2001 03:17 PM
Murray,
I have not put a RAID controller on my WIN2K machine as I saw no merit for this application.
I merely setup a spanned volume set in Win2k with 3 60 GB disks so my D drive looks like one 180 GB drive. My C drive is for the OS and apps only.
AccessDTV works just fine in this configuration and has no problem when recordings 'spill' onto the next drive in the volume.
Joe
gridleak 06-02-2001 03:38 PM
RAID distributes files across all the hard drives in the array simultaneously, a little of each file on each drive. When the array is full all drives are full. RAID 0 (zero) is frequently used for this purpose because it is faster than one drive alone.
- gridleak... biased toward HD
mkerdman 06-02-2001 03:56 PM
Joe
"I merely setup a spanned volume set in Win2k with 3 60 GB disks so my D drive looks like one 180 GB drive. My C drive is for the OS and apps only."
So, if I understand you, you are using the ability within the W2K OS and not a RAID Hardware controller.
That's exactly the setup I had in mind, including the seperate c drive for app and OS.
Is the PC dedicated to accessDTV?
If not, what else are you using the PC for?
HTPC DVD? Other functions?
Others have suggested Windoe ME over W2K for an HTPC.
I hate Windows, but I really hate Windows 95/99/ME!!!
Has W2K with Service Pack 2 had all the drivers you have needed for all drives, applications and PCI/USB hardware?
I read Dolby Digital is a problem for W2K. True?
Murray
Joe Q 06-02-2001 04:48 PM
Murray,
This discussion really should be in the HTPC forum.
Please see: http://www.avsforum.com/ubb/Forum12/HTML/010995.html
Joe
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
