How big in megs is a HD movie? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-03-2001, 12:57 AM - Thread Starter
deanzsho's Avatar
So I was just thinking that if I had a HTPC unit with a hd reciever card in it and first recorded the program to a hard drive, would I be able to then burn it to a DVD burner and then play back via the pc's dvd? or is the movie to big in megs to do so.
Just an idea
Dean
Live without discipline, die without dignity.
deanzsho is offline
post #2 of 7 Old 06-03-2001, 02:41 AM
boat-anchor's Avatar
About 15 Gigabytes (15,000 megs) per 2 hour movie.
DVDs at around 5 gigs can only hold about 1/3 of an HDTV movie.
Hard to believe that they can squeeze 80gb+ onto a 3.5" hard disk these days. $230 gets you an 80gb drive that holds about 5 HDTV movies.
boat-anchor is offline
post #3 of 7 Old 06-03-2001, 09:49 AM
CKNA's Avatar
It is way more than that. If you take OTA data rate
which is 19.4 Mbps (satellite is even more and go up to
80 Mbps on 36Mhz transponder)2 hour movie would take
a lot more than 15 gigs.
CKNA is offline
post #4 of 7 Old 06-03-2001, 11:20 AM
KevinYee's Avatar
The Matrix in HD recorded to a harddrive via Hipix takes up 17.5gb.
KevinYee is offline
post #5 of 7 Old 06-03-2001, 12:38 PM
bpearse's Avatar
Yes, a bit over 8 Gigs per hour of recorded HD movie on my HiPix. Gladiator, just over 2 1/2 hours, was 20G.
Bob
bpearse is offline
post #6 of 7 Old 06-04-2001, 06:52 PM
ADent's Avatar
19.4Mb/s = 0.01895 Gb/s
0.01895 Gb/s * 3600s/hr = 68.2Gb/hr
68.2 Gb/hr * 1B/8b = 8.5 GB/hr
8.5 GB/hr * 2hr/movie = 17 GB per movie.
ADent is offline
post #7 of 7 Old 06-05-2001, 11:05 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
Math never lies. I think this is once again a case of bits being confused with bytes.
Glimmie is offline
Closed Thread HDTV Recorders
