RECORDING HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-15-2001, 07:16 PM - Thread Starter
iwantmyhdtvnow's Avatar
IT THERE ANY WAY TO RECORD HDTV W/O THE DISH 5000 AND PVR? I HAVE DIRECT TV AND I WANT TO RECORD SOME OF THE BROADCASTS, EVEN IF I CAN ONLY RECORD OTA. ANY IDEAS ?
iwantmyhdtvnow is offline
post #2 of 3 Old 06-16-2001, 04:58 AM
chap's Avatar
Quoted: 64 Post(s)
Liked: 35
If you check out the HTPC forum you will find a good solution to store the video recorded from the hi-pix and WinTV-HD onto Camcorder DV tapes (forgot what they are actually called now).
STOP DVI/HDCP!!!!!
chap is offline
post #3 of 3 Old 06-18-2001, 01:52 PM
yogaman's Avatar
Chap:
The camcorder backup tools are called DVSpoof. This approach works.
-yogaman
yogaman is offline
Closed Thread HDTV Recorders
