Processor requirements for ADTV? - AVS Forum | Home Theater Discussions And Reviews
Old 07-16-2001, 10:15 PM - Thread Starter
ebr
ebr's Avatar
I'm considering the purchase of either an ADTV card or the HiPix (if they're really shipping now). I really think I'd rather get the ADTV card because I'm really going to want the timeshifting capabilities (TiVo has changed my life).
However, I don't currently have an HTPC but I do have an old PC that I can use for this purpose. It is only a PII 400 and the ADTV card says it requires at least a 500. The HiPix says it will operate on a 333.
I don't want to buy a new HTPC since this is all it will be used for right now (already have everything else I need for DVD in the theater). Is anyone out there using the ADTV card in a 400mhz machine?
Thanks for any help.
(hey, what happened to the email me when someone replies option?)
ebr
My Theater
ebr is offline
Old 07-16-2001, 10:36 PM
Abdul Jalib's Avatar
accessDTV says their card requires a minimum of a Pentium II 350 Mhz.
Abdul
<FONT size="1">Philips 60PP9601, join the Philips_HDTV discussion group
DirecTV + Sony SVR-2000 TiVo upgraded to 128 hours basic quality
Dish 5000 + HDTV Modulator
HTPC: Duron 750, K7 Master, Radeon LE, AccessDTV, Cybermail, Audiophile
Kenwood VR-407 receiver & subwoofer, nOrh 4.0 marble center speaker</FONT s>
Abdul Jalib is offline
Old 07-17-2001, 12:06 AM
dlarsen's Avatar
I had an AccessDTV card installed in a stock DELL PII 400 BX for a while.
Worked fine.
dlarsen is offline
Old 07-17-2001, 07:35 AM
chap's Avatar
Quoted: 64 Post(s)
Liked: 35
Originally posted by GregQuinn:
I'd just add that I'd seriously recommend using an Intel processor; I've had problems using Athlons with some capture/tuner cards etc; AccessDTV managed to reboot a Win2K box I installed it on, and that was using an Intel processor. That was NOT using the most recent software though.
Greg,
I have a feeling that anty problems you had with athlons didn't really stem form teh proccessor as much as it did the chipset the motherboard was using. After going through 7 or 8 of them in the past 6 months doing extensive testing I have found that the VIA chipset which is on most athlon MB's is total garbage. The AMD761 chipset works beautifully though. I have yet to touch an ALI.
STOP DVI/HDCP!!!!!
chap is offline
Old 07-17-2001, 08:44 AM - Thread Starter
ebr
ebr's Avatar
Hmmmm...I know when I looked at the ADTV site a while back, it had a minimum of 500...or, maybe I dreamed it.
Anyway, thanks for setting me straight.
One more question, which OS is most stable with the card? The machine as Win98 (no SE) now so I need to upgrade the OS anyway.
ebr
My Theater
ebr is offline
Old 07-17-2001, 09:53 AM - Thread Starter
ebr
ebr's Avatar
Okay, I found the reference to 500mhz. Its on the Digital connection site in the specs for the ADTV card.
So, at least I'm not crazy :-) but which is it...333 or 500? Cliff?
ebr
My Theater
ebr is offline
Old 07-17-2001, 10:35 PM
Kei Clark's Avatar
ebr,
It's wholly dependant on the type of system you have and the chipset utilized. With a BX chipset system, you should be able to run a 350MHz. We chose the highest common denominator to deter over-optimistic expectations.
Kei Clark
Digital Connection
Kei Clark is offline
Old 07-17-2001, 10:40 PM - Thread Starter
ebr
ebr's Avatar
Thanks for the clarification.
ebr
My Theater
ebr is offline
