Sencore - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-19-2001, 07:59 PM - Thread Starter
AVS Club Gold
TheFreak's Avatar
Hey does anyone know where I could find a Sencore unit that records for cheaper than there $8999 quote? Used is fine by me.
Only in America.....Don King
TheFreak is offline
post #2 of 5 Old 07-19-2001, 10:00 PM
Mark Hoy's Avatar
I'm curious why someone doesn't build a Sencore like unit
from a dedicated PC with a HDTV capture card. Not rugged
enough?? It could be made for < $2000 with a profit margin.
Mark Hoy - HomeTheater Addict
Mark Hoy is offline
post #3 of 5 Old 07-19-2001, 10:40 PM
kelliot's Avatar
I've never heard of an HDTV capture card.
Although there are some SDTV component capture cards in the $3500 range like the:
Vitec MPEG Profiler $2999
Pinnacle DVD2000 $3499
I wonder how much they would cost in a power buy?
Its cheaper to buy the DVDs.
Ken Elliott
[This message has been edited by kelliot (edited 07-20-2001).]
Ken Elliott
kelliot is offline
post #4 of 5 Old 07-20-2001, 10:43 AM
Glimmie's Avatar
Quoted: 630 Post(s)
Liked: 513
Well you can make an HDTV PVR for a little over $1000. There are two cards I know of. The HiPix and the AccessTV.
These however only record an ATSC bitstream off a tuner. That is good for off air and for those lucky enough to have an Echostar 5000 receiver with HDTV modulator.
Recording analog HDTV on a HOME computer is out of the question at this time. Remember that analog HDTV is decompressed. That equates to a data rate of 160MB (megabytes) per second. There is a product manufactured by Aja Video that will place HDTV on a PCI buss but that doesn't mean the computer can handle it in real time. The card is mainly intended for still capture and display. It also uses a digital interface so an analog convertor would also be needed, you are at $12,000 already.
Compression? Yes, that's the answer but at this time an ATSC type MPEG2 compression unit is a six figure device. Will home computer ever be able to capture real time uncompressed HDTV and store it? Of course. How long will it be before 10ghz processors and 10terabyte hard disks selling for less than $100.
Glimmie is offline
post #5 of 5 Old 07-21-2001, 10:11 AM
Mark Hoy's Avatar
Glimmie: You are correct, I was thinking of an ATSC capture.
JVC G1000 DILA
Stewart Greyhawk
Sony: SAT-B3, DTC-100,STR-DA777ES Receiver
Toshiba: SD-3109 DVD
Proscan 27" TV
B&W: DM601, CC6, DS6B, 800ASW speakers
Mark Hoy is offline
Closed Thread HDTV Recorders
