CROSS POST: accessDTV VGA Loopback and Toshiba 65H80 YPBR Inputs - AVS Forum | Home Theater Discussions And Reviews
Old 07-21-2001, 03:10 PM - Thread Starter
mkerdman's Avatar
I cannot get the accessDTV VGA Loopback Cable to work with the Toshiba 65H80 65" 16:9 sets YPBR Inputs.
accessDTV to Toshiba 65H80 YPBR Inputs works fine, but adding the VGA Loopback Cable causes the Toshiba to lose sync.
I've tried 640x480 and up.
I also tested an RCA Transcoder with the accessDTV card set to VGA out and again DTV is fine but VGA Output added causes a loss off sync and no picture at all.
Any thoughts??
Murray Kerdman
Murray Kerdman
mkerdman is offline
Old 07-21-2001, 03:29 PM
Abdul Jalib's Avatar
Yes, I have a thought. Get yourself a RPTV with VGA/RGB input! Failing that, you'll need to use a RGB to component transcoder cable; you won't use the loop-back in this case, and you'll have to run a component cable into each of your two HD component input or use a component video switcher if you have only one open input. Your experience with using both the loopback cable and transcoder cable sounds weird to me, but anyway don't use the loopback cable when you use the transcoder cable.
On my set, I use the VGA loopback cable and run a single VGA cable into my set's VGA input.
Abdul
<FONT size="1">Philips 60PP9601, join the Philips_HDTV discussion group
DirecTV + Sony SVR-2000 TiVo upgraded to 128 hours basic quality
Dish 5000 + HDTV Modulator
HTPC: Duron 750, K7 Master, Radeon LE, AccessDTV, Cybermail, Audiophile
Kenwood VR-407 receiver & subwoofer, nOrh 4.0 marble center speaker</FONT s>
Abdul Jalib is offline
Old 07-22-2001, 03:54 PM
Ken H's Avatar
Please see identical post at: http://www.avsforum.com/ubb/Forum11/HTML/015051.html
"Better living thru modern, expensive electronics devices"
tm
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
