hd recording setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-25-2001, 08:34 AM - Thread Starter
Kipp Jones's Avatar
is there a search word anyone can recommend or someone post a link to the setup and hardware requirements for recording hd on my pc?
Kipp
IS THAT A REMOTE CONTROL IN YOUR POCKET OR ARE YOU JUST HAPPY TO SEE HDTV?
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #2 of 3 Old 07-25-2001, 05:40 PM
ebr
ebr's Avatar
try AccessDTV, HiPix, ADTV, and record AND HDTV.
I would also try these in the HTPC forum as it is very active and a lot of those guys are into HDTV as well.
(preview - you basically have two options - Hipix or ADTV)
Good Luck.
ebr
My Theater
ebr is offline
post #3 of 3 Old 07-26-2001, 06:33 AM - Thread Starter
Kipp Jones's Avatar
Thank you for the information.
Kipp
Kipp
Closed Thread HDTV Recorders
