Where to buy firewire connector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-26-2001, 12:05 AM - Thread Starter
rodmanbra's Avatar
Looking for sources for 1394 for pvhd1000. Locally all i can find are 4pin to 6pin.
rodmanbra is offline
post #2 of 4 Old 07-26-2001, 12:08 AM
DSperber's Avatar
Quoted: 226 Post(s)
Liked: 186
That is exactly all you need... 4-pin firewire... just like
you'd use for your computer.
I bought a "generic" 4-pin 1 meter firewire at Micro Center
for about $7, opting to ignore the higher-priced ($14)
version from Monster.
Works perfectly with my DST50 <-> PV-HD1000.
DSperber is offline
post #3 of 4 Old 07-26-2001, 08:11 AM
beavis's Avatar
I think the 'Bra is asking where to get a 4pin to 4pin firewire cable. I've been buying most of my cables from this place recently: www.pccables.com
They're cables are high quality and are very reasonably priced.
Jeff
beavis is offline
post #4 of 4 Old 07-26-2001, 11:09 AM
waters's Avatar
I bought mine from here and was very satisfied. They are in the Orlando area.
http://accessories4less.com/advscrip...st.asp?area=13
George Waters
[This message has been edited by waters (edited 07-26-2001).]
waters is offline
Closed Thread HDTV Recorders
